Question about Cyber Acoustics Audio Players & Recorders
Control Pod CA-3090
Not particularly a problem in and of itself, but rather asking a general question about the design of the control pod. It was recommended elsewhere about 3 years ago that an issue with my speakers may be caused by build up in the control hub for my volume. I cannot for the life of me figure out how to disassemble it to clean it. If someone would be so kind as to instruct me how, it'd be appreciated.
mana666
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
  • 365 Answers
SOURCE: control pod on bose companion 3
try to check the circuit board with an expert
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Posted on Jan 02, 2009
SOURCE: Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Posted on Sep 15, 2009
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
Printer fails self test, what should I do?
It would be very helpful to know the particular error code the printer returns, but it may not be necessary. In general when printers of your model's basic design fail their self-test, the RAM inside the printer needs to be replaced (assuming the self-test includes print head alignment).
However, given the nature of the printer market for some years now, I recommend looking at a replacement printer which will cost less than any replacement parts for your current printer. On top of all the mentioned benefits, you'll get a much more efficient machine which will quickly pay for itself in savings from ink.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Dec 05, 2015 | Epson FX 2180 Matrix Printer
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
How can I replace the harness
I'm not expert in these particular items, but as with all safety related equipment, if it designed to be a user replaceable part, it will be obvious how, easy to do it, and will likely have instruction stickers stuck on the device itself. It is never recommended to attempt to repair any safety device, particularly those parts of the device that is so intrinsic to it's safe operation, not to mention a device that protects something so precious :-)
Nov 17, 2014 | Cosco Alpha Omega Elite 5-Point 22-155
How to apply for intenships/learnerships for 2014?
Are you asking about internships at Fixya, or at tech sites in general or internships in general?
If you are asking about internships in general, I recommend researching the industries you are interested in. Decide what kinds of companies you are interested in, and what kind of skills you want to build. Write your dream companies directly, then write their competitors. If you are sure, find the social networking sites for each industry, like Design = Behance or tech = Stack Overflow. Usually social networks have job boards like Stack overflow's: http://careers.stackoverflow.com/
Also, if you are still in school/university, your school probably has career boards.
LinkedIn is great too. Search people in your network in the industries that interest you, then write them directly asking for recommendations/introductions/"Informational Interviews"
Best of luck!
Sep 26, 2013 | FixYa Computers & Internet
Machine asks if we want to clean it after each load. Can that be stopped?
Hello Kelly, thank you for your question! Generally speaking, once the cycle is entirely completed, it is designed to ask if you would like to run a "Clean" cycle. Therefore, there isn't a way to prevent the unit from offering this particular option. However, if your washer has run through a clean cycle and it is still asking to do so, then the issue may be related to communication error with the control. Thank you for allowing me to assist you in some small way!
Aug 08, 2013 | Frigidaire ATF6000ES Front Load Washer
No audio coming out
"A no-sound problem generally indicates that you have a driver issue. So what I would recommend that you do is go to you manufacturer's website, Dell, or HP, or whoever, and download the most up to date driver from their website for your particular model. Models are generally on the front of the machine. This goes for the same for a laptop, or a desktop. And then if you have a specific, newer sound card that you put in yourself, go to that particular manufacturer's website and download the driver there. And then that should fix your problem. If it doesn't then do something that's sometimes so painfully obvious that it doesn't really click with you, check the actual connections on the machine. Also, a good test is to take an I-pod or CD player, anything with a headphone jack, and plug it into the yellow or the green connector that's on your speakers to make sure your speakers are working correctly as well. Some card problems generally originate from malware being on your machine. Some malware will attack the sound driver itself and delete it from the system and you have to manually re-add it. So one good deterrent from keeping this from happening is to get you know up to date anti-virus and malware protection like Spybot or Ad-Aware. And also make sure those programs are up to date."
Feb 22, 2011 | Computers & Internet
Volume varies by itself on the Yamaha htr5840 Receiver
The pod that controls the volume knob is either very dirty or needs replaced! (If you remove knob you will see the shaft of the volume pod go into the pod itself) You may try cleaning with a can of high pressure air by spraying short bursts of air in and around the pod area! If that doesent work you will have to replace the volume pod!...Please rate my response! Thank You!
Jan 11, 2009 | Yamaha HTR-5840 Receiver
How u turn up the volume on a ViewSonic monitor w?Built-in spkrs?
when i push the volume up or down button on the side of the monitor, a key icon pops up on the bottom left corner not letting me control my volume
Dec 23, 2008 | Computers & Internet
All I need is the control pod for the Gigaworks S750
I had an extra one but I sold it. According to creative labs they do not sell any replacement parts for the speaker systems. The best suggestion that I can give is to check craigslist and ebay for the control pods.
Dec 13, 2008 | Creative Labs Gigaworks S750 Computer...
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
