Olevia VCF-42FDV1U Flickering Screen
I received this TV to fix and was told if I could I could keep it. Its a nice 42" 1080P flat screen and I have light experience in fixing small things and know my way around circuits. I'm having an issue where every so often, the screen will go black and I will see flickering lines across the screen every 5 inches or so. This happens once every 5 minutes or so. Occasionally the screen will also get distorted. Most of the time it displays the image perfectly but it has this issue once every 5 minutes or so and has to be turned off and back on to be fixed. I checked a few of the easily visible capacitors for bulges and did not find any. I also uploaded a youtube video of the Issue and the TV here: http://www.youtube.com/watch?v=hjGYyAAHMBY&feature=youtu.be Any help would be appreciated!
    Top Expert:
  • 12,223 Answers
Test the IPM fail, cable connection. God bless you
see the diagram attached.
Olevia VCF-42FDV1U Flickering Screen - 5126949f-6543-41b9-b8a5-c8c794460d12.gif
Posted on Jul 20, 2013
SOURCE: Philips 32PF7320A black screen
upgrad the firmware in the TV. This problem was resloved by philips with the software fix. you can locate the firmware on philips.com. good luck!
Posted on May 25, 2007
techman007
  • 1112 Answers
SOURCE: Black flickering sections of the screen
Hi:
This prolem could be one of two problems, first the inverter board may have bad connections on it, its used to light the lamps in the back of the PDP Panel (SCREEN) second the Digital board may becoming faulty, there may be a faulty IC on the digital board or main system control board.
But first I suggest you take off the back and disconnect all plugs you see and reinsert then firmly to make sure they are on tight.
Posted on Apr 03, 2010
SOURCE: I have a sony bravia
You Tv has a bad LCD panel... Very expensive...
Posted on Nov 26, 2010
SOURCE: Sony Bravia LCD KDL 46V4100 has distortion with
I have this exact same problem on my same model TV. It started just before Christmas. Have you been able to find any resolution?
Posted on Jan 07, 2011
Mas Baz
  • 177 Answers
SOURCE: i have the samsung fpt5084 plasma tv, and it has
hello,
I've watch your problem on youtube , that problem can be from main board. But to make sure main board problem, you should check without inputs first. Unplug all input (HDMI, Component, AV in, PC).
Than turn on your tv again. If that conditions still appear, i suggest you to call samsung technician to repair it.
Good luck.
Posted on Apr 07, 2011
Need a repair shop in NY for out of warranty Olevia
Just about any TV repair shop in NY city can fix it for you unless it is under warranty. If it is under warranty, let me know and I will look up an authorized service center for you. But you do not need an authorized service center if it is not under warranty.
Nov 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
"my olevia VCF-42FDV1U got zapped by lightning that hit an exposed cable line outside,now the power light comes on but no picture?
if just only raster then can not get any channel the tuner get bad which some parts get burned. if you don't have an idea how to replaced the parts just leave it to the trained tv technician or service shop.tuner is not too expensive unlike replacing an lcd monitor.
Aug 14, 2012 | Televison & Video
My tv keeps telling me "invalid format". It is a HD tv and everytime that this "invalid format" comes on the screen it skips. How do i fix that?
Okay you need to call the company and they will give you some firmware to download to your TV. Just tell them the same thing you told us about what the TV is doing.
Aug 18, 2010 | Olevia LT27HVX 27 in. LCD Television
Child hit screen of olevia flat screen and now it has a big x with no color just black
If the screen is damaged then, is not worth fixing. The panel is more than what the TV is worth.
Good luck
N Sabre
Nov 08, 2009 | Olevia LT32HVM 32 in. LCD Television
Olevia lt 30 hv
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
Dec 24, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
