Question about Canon imagePROGRAF iPF650 largeformat colour inkjet InkJet Plotter Printer
Error message 03800500-2f47
Carefully replaced print head with new print head and still getting same error message. Any ideas?
SOURCE: print head alignment failed
Head Align Failed
Posted on Apr 17, 2008
komguy
  • 2306 Answers
SOURCE: We keep getting an error message
Yes, you need a new printhead, QY60061-000
around $40.00
Posted on Jul 01, 2009
JackHeath
  • 1049 Answers
SOURCE: I get error 1401 - print heads not installed (properly). WRONG!
Make sure you removed all the shipping tape from the bottom of the cartridges and that you installed the cartridges in the correct bays.
Posted on Oct 06, 2009
  • 159 Answers
SOURCE: Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Posted on Mar 15, 2010
SOURCE: iPF610 Canon "Print head needs cleaning"
This has happened to me on my IPF8000 twice in the middle of jobs. I have had to purchase 2 sets of printheads..each set has only printed 3400 square feet....
Posted on May 23, 2010
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Error message "head open" any ideas why please?
Check the microswitch on the leftside of the print head.
Sometimes a part is missing or the print head is not correctly mounted
Jun 15, 2011 | Toshiba TEC B-4700-I/O-QM Thermal Label...
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Getting "Error Number : 1403
Not sure what you are asking. You posted the solution?
Jan 24, 2011 | Canon Office Equipment & Supplies
HP Photosmart C5380 All-in-One. Ink system Failure. Oxc19a0023 My computer has Windows XP and IS is Internet Explorer.
The first step is to try resetting the printer. Turn the unit off, unplug the power cord and wait 30 seconds before reconnecting the power. Turn on the printer. If you still have the error message, you may need to clean the print head. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=au&lang=en&product=3560275&docname=c01458034 has the details.
Remove all of the cartridges, lift the handle on the carriage until it stops. Lift the print head straight up. Once the print head is out, you need several lint-free cloths and distilled or bottled water. With a damp cloth, wipe the electrical contacts from bottom to top (do not go past the edge). Then wipe the edge between the ink nozzles and the electrical contacts - wipe away from the nozzles. Wipe the ramps on either side. Dry all three areas.
With a new damp cloth, wipe the contacts inside the printer from top to bottom until no ink remains on the contacts. Dry this area.
Reinstall the print head and lower the latch carefully. Reinstall the ink cartridges making sure that they snap into place.
Check if the error message repeats. If it does, try resetting the printer (power cord unplugging cycle). If you still get the error, the print head may need to be replaced. If a new print head is in and the error occurs, talk to HP support if the printer is under warranty. You'll have to decide if these last two steps are worthwhile if the printer is out of warranty.
I hope this helps.
Apr 24, 2010 | Office Equipment & Supplies
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Print Head error
Greetings Morbica,
As a member here I drop in now and then. I saw your post and I thought I would review.
Since the time of shipment has passed, your only option is to replace the print head again. Before I help with that, please check the following. Did you make sure the print head was snapped into place and secure. Also, did you make sure the ink carts were snapped into place. These actions can make a difference.
Once you have completed these actions and things are still not working for you, let me know. You can write to me at ronbaird@kodak.com or leave a message here.
Talk to you soon,
Ron Baird - the friendly Kodak guy
May 22, 2008 | Office Equipment & Supplies
Canon imagePROGRAF iPF650  largeformat  colour  inkjet InkJet Plotter Printer Logo
947 people viewed this question
old marine
old marine
