Question about NetGear Computers & Internet
89 9 Our wifi is not connecting to mobile i phone
Can you set up, AND use, CHROMECAST, with ONE mobile phone/tablet that has mobile data?
You are confusing yourself.
Mobile Data uses the internet direct from the mobile device.
WiFi uses public or private connection from phone to Router to Internet.
Mobile Hotspot or 'tethering', allows you to connect one device, through another to use data or wifi of the host device.
In your case, you want to connect Chromcast via your device using Mobile Data. Yes you can, see the link for explanation and videos.
can chromecast use mobile data Google Search
Jan 08, 2018 | Verizon Cell Phones
How do i get internet connections?
Richards, Smartphone How to connect to the internet, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Your SmartPhone to Internet Only Using WiFi
How to access the internet on smartphone
How to Connect Your Android to Your PCs Internet Connection Over USB
Aug 09, 2016 | Nokia Lumia 630 8GB Unlocked GSM Windows...
How to connecting wifi networks
Hello Pavan kalya naidu,
Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
now your wi-fi connect on your mobile phone .
Thanks,
Mar 18, 2016 | Cell Phones
How do i change countries
You write: "Once the computer or mobile device was able to get a successful check service and changed the Netflix country then you can take our DNS on your computer or mobile device if you want to as the effect on the wii will last."
Do you mean that once the check service and change has been done that I can change the DNS on the computer or mobile device back to its old address? I don't know how that would work because doesn't the wii need the internet connection to work each time it plays. Or are you saying that once that change is made, it can run on an old connection using a Canadian based IP.
My concern with switching the IP on my Wifi is whether this will affect how my service provider will bill me for my android. You know how you get roaming charges when you travel? I am thinking though that the service provider allows people to use wifi connections across the world. So, I am thinking it is OK if I use my android phone at home on the wifi...technically, wifi use shouldn't even be something the mobile phone company can track, let alone bill.
Read More... Wifi Router Region setting what does this affect Transmission power And Linksys Support Phone Number
Thanks,
Sep 05, 2014 | Computers & Internet
I have no wifi so will i connect with wifi on my mobile
you are not required to have wifi at your home or anywhere else, there are wifi hotspots such as Mcdonalds and other places. If the data on her phone is turned on you can pick up the wifi on your phone which may cause you to have data charges on your bill. You should be able to turn your wifi off so that this does not happen you may also be able to turn off your data under your setting>cellular>cellular data and then you will not be able to connect to any data at all. Hope this helps
Feb 13, 2013 | Samsung Cell Phones
How do i connect my phone tomy computer using wifi
this is the universal problem wifi requires a no separate from all devices connected to it he cannot connect a phone or any other wifi device a wifi enabled laptop or computer you can't connect to wifi printer to computer either in the same respect to the phone
Apr 01, 2012 | Sony Ericsson Vivaz Cell Phone
Cannot connect with wifi on mobile.
For wifi connection:
1. Make sure that you have a working modem router in your premise.2. Turn the modem/router on.3. Select settings icon from your mobile phone.4. Select Wireless Connection or WI-FI connection.5. Select options, then select connect.6. You will be asked for the WEP or WPA key. This is depending on what is the security option that you selected in the modem settings. (for modem settings you can contact your internet service provider or OEM for the modem)7. If you are aware of your pre shared key, just type it in the password option from the mobile screen.8. Once connected, you can use the wifi as your active connection access.
Jan 14, 2012 | Cell Phones
I have the Samsung Ch@t 335. When I try to connect to the wifi it will connect for about 5 minutes. Then you try again and it will say 'Failed to connect to network. Authentication failed.' If you...
I think your mobile has been very old or you use to connect your mobile to wifi a lot before,there could be some problem with your mobile software so once reinstall your mobile operating software
Aug 23, 2011 | Samsung Cht 335 Cell Phone
I want connect a internet to my mobile by wifi the mobile asking the password
Hi. There's a security key to the wifi were you are connecting. You need to ask the owner of the wifi what's the security key. You need to input it before you can connect to the wifi
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect my phone to enternet?
You may use mobile internet or through wifi. On Mobile internet, you need to have the APN settings of your mobile carrier. Also try to turn on your wifi, and check if you have available wifi hotspot near you.
Feb 22, 2011 | HTC Wildfire Cell Phone
Computers & Internet Logo
22 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
