Question about Generic Android 2.3 7 inch 2 in 1 Swivel Netbook and Tablet in one
Android tablet/netbook wont boot
I cant get my tablet to boot past the android screen
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Will not boot-up or start
Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
If it won't power on at all, try out these instead:
What to Do When Your Android Phone or Tablet Wont Turn On
My Android Tablet Wont turn on Anymore And cant take the back off
If those do not help, then contact the manufacturer.
I post on behalf of HP.
Jul 29, 2015 | Tablets & eReaders
How do i get to the BIOS on a craig 7" netbook clp218?
I have no idea about these craig things which are Android machines, Try this.
Cannot be worse than you got.
How to do a hard reset using external keys? If your tablet is completely locked up and you cannot access the menu functions, use the following method to perform a hard reset using external keys on your tablet:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
If it doesn't work try search engines for 'Android tablet hard reset'
Sep 10, 2014 | Computers & Internet
Visual Land Connect Android 4.0 wont boot
Hold the power down and press the -volume button down to reboot
Sep 29, 2012 | Visual Land Connect Android 4.0 Internet...
Generic Android 2.3 7 inch 2 in 1 Swivel Netbook and Tablet in one Logo
22 people viewed this question
Top Generic Computers & Internet Experts
D. E. Hev
Steve
Are you a Generic Computer and Internet Expert? Answer questions, earn points and help others
