Question about Dryers
Samsung eo error
My client's Samsung dryer DV218AEW XAA has an error code EO how can I fix it I'm the technician
  • Dryers Master
  • 15,478 Answers
The code means that the controller or main board is having an issue with the EPROM. Take the top off and you should see a tech sheet for service persons. IT will tell you the troubleshooting steps. BE SURE TO UNPLUG THE UNIT
Posted on Jul 24, 2013
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 1531 Answers
SOURCE: I have a samsung dryer.
there are two things you may need to replace if the unit works on timed dry then you first thing to replace is the moisture sensor bar.The other thing to replace is the main electronic control board.
Posted on Mar 02, 2011
heatman101
  • 43501 Answers
SOURCE: SAMSUNG GAS DRYER DV 328
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Posted on Aug 14, 2011
heatman101
  • 43501 Answers
SOURCE: My Samsung DV219AGW/XAA dryer has no error codes.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 21, 2011
My dryer is showing an eo code
best bet is to call a repair service and have them fix the problem
Jul 14, 2016 | Samsung DV337 Electric Dryer
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
How do I replace the drum assembly on Samsung DV218AEW//XAA dryer
You may not have a bad drum as that is the least likely item to go bad. What will go bad are drum support axles, support rollers, and bearings that when they go bad will cause the drum to sag and the belt will go loose and may fall off. Please use this link to help you figure which one it is and order the correct part for your dryer; http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/10---/Dryer-makes-noise?r=%2fShop-For-Parts%2fa8b160c26%2fSamsung-Dryer-Drum-Tub-Parts
Good Luck!
Rich Lilja
Oct 01, 2014 | Samsung DV218AEW Electric Dryer
Where is the fuse box and heating element in a samsung dv218aew/xaa?
both are inside the outter casing...
remove the back and then call an applience store tech to come do his free discovery process.
watch the guy while he works... and then follow up with a $20 bill and a 6 pack ... he will likely do you right in the repair.
Apr 12, 2013 | Samsung DV218AEW Electric Dryer
Samsung DV218AEW/XAA not heating
If the technician that came out told you he simply reset your heating element, he was not telling you the truth. Heating elements themselves cannot be reset. The element is either good, or burnt out and would need to be replaced. More common on modern dryers is that the thermal fuse on the side of the heater duct will blow out and needs to be replaced. This is usually caused due to poor air flow because of a lint blockage in the outlet duct. I would recommend calling a good, reputiable service company to repair the issue and to check the outlet duct as well. To get to the heater duct assembly, the top cover, control panel and front panel (including the door) must be removed.
Mar 25, 2013 | Samsung DV218AEW Electric Dryer
I a samsung dryer showing error code eo the e is missing on the top line. It runs for 2-3 mins then shuts off showing code
If you take the unit apart by lifting the whole top off, you should see the techinical spec sheet for service techs. Make sure you unplug this first. E0 means that there is a problem with the controller. BUT that problem could be the control board or main board.
Aug 15, 2011 | Samsung Dryers
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Dryers Logo
413 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
