My unit is in standby mode and service mode manual
    Top Expert:
  • 12,223 Answers
They have a small switch, transfer the switch a normal operation see you owner manual , and fix it.
Otherwise you must open and see inside the switch is defective or dirty.
God bless you
Posted on Jul 20, 2013
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
Yamaha DSP-A2070 not working, and not power up in standby mode. All the fuses is OK. Please help ?
start reading on page 14 of your service manual.
let me know if you need further assistance!
Aug 20, 2012 | Yamaha Audio Players & Recorders
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
I am seeing the code H02 on the display panel when attempting to play a DVD. I have attempted to play several different DVD's. I have also switched the unit to standby mode then back on. I then...
This is what the manual says:
Trouble may have occurred. The number following "H" depends on the status of the unit.
Reset procedure:
Press [POWER ?/I] to switch the unit to the standby mode and then back to ON. Alternatively, press
[POWER ?/I] to switch the unit to the standby mode, disconnect the AC power supply cord, and then
reconnect it.
If the service numbers fail to clear, note the service number and contact a qualified service person.
I know these things you have tried so here is the contact information for customer service:
In the U.S.A., contact the Panasonic Customer Call Center at
1-800-211-7262, or e-mail consumerproducts@panasonic.com, or the
website (http://www.panasonic.com).
Mar 01, 2011 | Panasonic DVD-S35 DVD Player
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Aug 30, 2008 | Panasonic DMR-ES35VS
Bulb Reset issue
I had the same problem and called Sony, they just said to keep trying what the manual says to do, but make sure the unit is in standby mode. I tried in powered mode and in standby mode many times and it did not work. Then I tried again the next day when the unit had been in standby mode for an extended time period. I hit the four buttons like the manual said, all four in quick succession. I also tried the four buttons in many different sequences from what the manual said. When I powered back up the lamp timer was set to zero, finally! I think having the unit in standby for an extended time was the key. The Sony rep really emphasized the need for the unit to be in standby.
Oct 01, 2007 | Sony VPL PX40 Multimedia Projector
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
