Gets to video play screen and then wont play?
I have an emachines eM250 and a LG Slim GP08. I want to play a dvd movie, but when I insert the disc into the driver, but then stops. It seems to run and when I open my device and drivers tab it recognizes what movie I have in the drive, and the Sony play screen appears. At this point everything seems to work fine, but when you hit the play movie button the screen disappears. You can reload it, but it works the same way every time. Is there some install disc I need to insert into the drive that I am missing? Any ideas on what is wrong, or what I'm doing wrong?
    Top Expert:
  • 12,223 Answers
Restore go to control panel, use the utility system restore and put the last date that you know was working good.
Otherwise, see the device administrator download the update driver and uninstall the old one corrupted, and install the new ones
God bless you
Posted on Jul 21, 2013
SOURCE: pioneer dvd-rw dvr-k17a
i found the solution at microsoft support website, but i just found in portuguese, so im gonna try to explain how to solve it.
u need to go to start menu and then on the star search u need to search for "regedit"
when u are inside the regedit, look for this subkey "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
on the right side u need to del 2 subkeys
"upperfilters" and "lowerfilters"
close the regedit and restart the windows.
hope i can help u guys. it worked for me.
Posted on May 15, 2008
peacemaker23
  • 200 Answers
SOURCE: HL-DT-ST DVDRAM GSA-T20L ATA Device
ok you can do two things to fix it
first of all go to start
go to run
type regedit and hit ok
now in the registry go to this path
and remove both upper and lower filters from the right pane
now close the registry editor.
reboot the computer and see if that fixed it or not
if not the download the drivers from this website.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3224052&lc=en&cc=us&dlc=en&lang=en&cc=us#
just select the operating system that u have and then download it and reinstall the driver and then reboot the computer
that should be it
if still not working then i guess its a hardware issue
cheers
Posted on Sep 06, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Posted on Sep 18, 2008
hardkiss69
  • 43 Answers
SOURCE: GMA 4082n device driver not working properly code 39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
pankaj_dic
  • 1252 Answers
check whether the device is detecting properly on bios or not
Posted on Oct 01, 2008
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
I have a problem on my computer which is just reformated and upraded to Windows7 and now i have local disk c but i dont have local disk d..i want to watch a movie using my LG GP08 LU10 but it cannot find...
Did you try connecting to another USB Port?
1. Go to Control Panel
2. Device Manager..
3. Delete ON USB all of it
4. Reboot
It should reinstall all USB devices.
God Bless You!
Feb 05, 2011 | LG GP08LU10 8x DVD RW DL USB 20 Slim...
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
I have a MacBook, is the LG external dvd drive compatible
Both the LG GE20 Super Multi External DVD Rewriter & the LG GP08 Super Multi External Slim Portable DVD Rewriter are Mac compatible.They both use USB 2.0 interface to connect to the computer.
Jul 14, 2009 | LG Computers & Internet
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
Mcd288 problem
Try not to use any rental dvd discs or dvd burner discs. Go get a brand new dvd movie(again,do not burn a DVD disc and play in this unit.) and put it in see if it works? Should have at least 2-3 movies for testing.
If you have tried to put in some BRAND NEW DVD movies and still doesn't work,you have a problem with the unit.
Jul 23, 2007 | Philips DVD Micro Theater Shelf System...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
