I have power to my packard bell store and save 3500 as the green light is on and the computer is registering that it is there as it beeps when I attach the device, but the icon does not appear in the my computer section. Any advice?
Check to see if you can see your drive in DOS. To start ...run ...type in CMD and hit return. Then type E: (it should be the last drive letter...if not e: try F: etc..).....and return ...then type DIR and hit return....can you see the files on the drive ? might be security software you have running or it might be one of the Microsoft services not running....try the above 1st it should prove if its a windows problem..
Check to see if you can see it in dos....go to start...Run...type in CMD in the box and hit enter. Then type e: and hit enter (more than likely if you just have one HDD and one CD rom the external should come up as E: drive) If it changes to E: then type DIR (this will let you see everything on your external drive). It be be an application that is stoopping it from coming up in Computer Manager or it might be one of the services not running...try this and report back....stupid Question but did you try and reboot...regards
