Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
Changing colored lens on glow buoy
I am having a problem removing the colored lens on my glow buoy to change to a different color, any suggestions
The way I change the colored lens to the glow buoy is with three standard screw driver, about a 3/16" head good 4" shank or longer. If you look close you can see four grab tabs in the middle of the lens, these hold on to a lip on the clear lens. Twist the colored lens till you can get to three of the tabs. I couldn't get to all four do to the triangular shape of the top. Slowly wedge the driversunder the lip of the colored lens center to the tabs one by one, alternately pressing the screw drivers deeper once you get the to where they wil continue no futher, due to the bevel in the lens, take the two drivers opposite each other and push them in forcing the edge outward. The lens will pop off violently, and most likely shoot the third screwdriver across the room, but after changing them a few times the lips wear down soon you will be able to pull them off with a good pair of fingenails. Hope this helps, you may scratch the lens a little, also the covers have a bit more flexibility then I thought I was afraid to break them but now I see the give.
Posted on Jul 08, 2015
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: I need a new bulb for my glow buoy pool light!
The Glow Buoy swimming pool lights were designed so that the bulbs can only be replaced by a licensed pool supply store. If you open the light yourself, you will void any warrantly and risk breaking the unit. Becuase of this, they don't sell the exact bulbs that you need unless a pro is installing them.
Posted on Jun 29, 2010
jharwell668
  • 640 Answers
SOURCE: I need to purchase/order a new plug in device for
You might want to check with backyardcity.com. I know that they sell an assortment of swimming pool lights. If they don't carry the charger, they can probably direct you to the manufacturer. If you have a number to the manufacturer, you might want to contact them directly. Also, a local pool store might carry them.
Posted on Jul 08, 2010
Battery will not hold a charge. can i replace the battery
As far as I know, you cannot change the batteries on these swimming pool lights. If the rechargeable batteries are no longer holding a charge, you will probably have to replace the entire light.
Jun 04, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Change to print in greyscale
I have some questions and something you may want to try.
did this just start happening? have you tried printing color from a different file or document to verify the problem occurs every time regardless of what is being printed?
if you have tried this then may I suggest:
at top of browser screen try
((clicking))
file
Print
Click properties button
once print menu opens click color tab
Make sure your gray scale only button is unchecked
and color or high quality is checked.
also, view your choices for color management.
You may find the answer to your problem by doing this.
If this does not work remove ink cartridges again and replace.
if it is a new cartridge make sure tape tab has been removed.
I have had customers forget to do this and it is a common mistake.
If problem still persists. buy a new color cartridge this will help determine if it was a defective cartridge or print head.
Please post your feedback and Vote if the problem as resolved as per your satisfaction.
May 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Is it easy to change a color wheel like the lamp? or i need to take it to a tv specialist?
the colorwheel is not as easy as the lamp to change. you have to remove the light engine from the tv and remove a cover from the lens and a cover from over the colorwheel then two screws that hold the color wheel and two wires. sometimes new codes must be input into the service mode. i suggest letting a professional do it.
Jan 30, 2010 | Samsung HL-R4264W 42" DLP HDTV
I need a new bulb for my glow buoy pool light! how much and were thanks!!!
Jul 07, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Glowbuoy light battery needs replacement
Hi, replacement battery can be found on amazon, here: Finally charging for our multi device world. I hope this helped. Cheers
Jun 10, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
How do you change the light color in the radio
most vehicles have a cover over the light inside the car. there you can remove the cover and replace the bulb with another color bulb at a nearby autozone or parts place of choice there youll have a variety of different color bulbs
May 11, 2009 | 2006 Scion tC
My glow bouy won't hold a charge.
my glow bouy just keeps flashing on and off after recharge, had it about 2 years hardly been used
Apr 10, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My Nikon D70 lcd screen doesn't display correctly the colors on the screen show in bright glowing colors, but the pictures print out great and display well on my computer screen. Is there a setting that...
You are looking at two different monitors with different settings. In most cases you will need to do some editing yourself on your computer because of the difference. Or the brightness can be done in a lab.
Mar 22, 2009 | Nikon D70s Digital Camera
Re: PS2 Will Play PS1 games but sticks in browser mode for PS2 Games
when you change the laser it is not just a matter of remove and replace ..you have to have the right gear to set up the lense..all versions have different settings
Jan 19, 2008 | Video Game Consoles & Games
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
136 people viewed this question
Top NRS Pool & Spa Experts
Ian Kime
Ian Kime
Tom Chichester
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
