Pensonic service mode
My unit is in standby mode.pensonic tv.17"
    Top Expert:
  • 12,223 Answers
The unity has small switch for service, try to pass normal operation. Otherwise you must open the tv and see the switch for faulty or dirty try to clean with contacts cleaner solvent
God bless you
Posted on Jul 20, 2013
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: pensonic service mode
Check this link for details. Pull up older posts there.
Posted on Sep 25, 2012
Remote code for my Panasonic TV Viera TC-P50U50 to program my universal remote
Pensonic TV 3 Digit Remote Control Codes:
095
863
261
Pensonic TV 4 Digit Remote Control Codes:
3778
3779
2186
To program most universal remotes to work with your Pensonic TV:
1 - Hold the setup button until the light stays red or green.
2 - Be sure the light stays illuminated.
3 - Enter one of the remote codes provided above.
4 - Remote blinks and code is saved.
Nov 14, 2017 | Panasonic Televison & Video
What code to open the service mode of pensonic model led-2424
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2016 | Televison & Video
Can i reset to the original settings of my crt tv pensonic HG-2165FLT
You have to enter its service mode to make a reset. There are two ways to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 24, 2016 | Televison & Video
Good day!have ah pensonic model ctv-2155uv trouble is no picture in tv mode,but if u switch to video mode,no problem.only in t.v mode my atenna is no problem.
Your problem is with the tv tuner. Use a vcr tuner connected to your antenna, connect vcr to tv set video input and you have a working tv for normal reception.
Nov 18, 2015 | Televison & Video
How to reset eprom pensonic tv
What is the number of EEPROM used? The number of main system control memory IC? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Televison & Video
One horizontal line on TV
Either bad solder connections on the vertical output IC or bad part in that circuit, IC or something else. I presume it is NOT a flat panel set but has a picture tube as no model number is listed.
Dec 15, 2012 | Televison & Video
How much power does a computer use while in sleep mode?
If your computer is a desktop and using CRT monitor it will consume 60 to 250 watts when being use. But if in standby mode or sleep mode it only uses 1 to 6 watts. A typical CRT 17" monitor is consuming 80 watts and the 17" LCD monitor is consuming 35 watts it defends on the type of unit is being used. hope this may help good day and best regards.
Sep 17, 2011 | Computers & Internet
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
