Location of evaporator in Daihatsu Terios - Heating & Cooling
5 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: 2008 Daihatsu Terios engine number location on the car
wow someone knows their stuff ,if not sure where numbers are i ask in our local annual vehicle inspection station ,dont you have one??
Posted on Nov 13, 2008
bromleyjmark
  • 3 Answers
SOURCE: Cigarette lighter fuse for Daihatsu Terios. Where
the fuse you are looking for is lockated under the dash at the drivers side if you remove the small change hilder you will see it it a blue 15 amp on the right hand side of the box hope this helps
Posted on Dec 18, 2009
  • 80 Answers
SOURCE: Daihatsu Terios hydraulic breaks
Hi, buy a couple of pints of brake fluid, dot3 or 4, get a bleed pipe from your local car store, connect to each bleed nipple behind each wheel, with the nipple open press brake pedal down several times, do one at a time, as the fluid drops in the brake fluid resovoir keep topping it up so it does not run out, do this to all the 4 wheel starting with the one that is furthest away, you sould end up with a bottle of very grimey brake fluid, good luck.
Posted on Feb 23, 2010
alicantecoli
  • 22326 Answers
SOURCE: I have a 2000 daihatsu terios, I can't find where I add and check the transmission fluid, any ideas?
I thinmk this is like a lot of more modern vehicles where its a dealer only job ,it doesnt have a filler but a special type of tool that pumps fluid in from underneath till it reaches a level
Posted on Dec 19, 2012
Daihatsu terios fuel pump duse not pump fuel when the ignition hase been swhitch on onley after n fewe times switching on and off
The problem could be the fuel pressure sensor, the fuel pump itself or a problem with the fuel pump relay circuit. If you have a manual handy it will show you the location of the components.
Feb 04, 2018 | Daihatsu Cars & Trucks
Hand brake tension 1.3 terios
Yes. you can adjust the tension on the brake. It will be under the car by where the hand break is or adjustment will be back by the wheel.
Apr 19, 2016 | 2004 Daihatsu Terios
Where is the fuel filter on my daihatsu terios 2002 1.3
the location can be either next to the which fuel tank require you to work under your car, or it would be located on your firewall in your engine bay.
Feb 01, 2015 | Daihatsu Terios Cars & Trucks
Dec 19, 2012 | Daihatsu Cars & Trucks
2007 daihatsu terios overheating
air lock or thermostat stuck try flushing with hose pipe
Aug 12, 2012 | 2007 Daihatsu Terios 1.5i
Where is the thermostat in dhaiatsu terios
Hey, I have attached a link where I helps to find the thermostat on a 99 terios.
It states to follow the left bottom radiator hose to the "upper left side of the engine block"
http://www.daihatsu-drivers.uk/node/14258
I have also attached links to other forums which explain the same in a different way to help you find it. Where is thermostat located on 99 Daihatsu Terios
I hope this helps
May 03, 2012 | Daihatsu Terios Cars & Trucks
How do i change the gearbox oil in my daihatsu terios
In a Daihatsu Terios 1.5 2007 model, Where is the gearbox oil check done.
Feb 19, 2011 | Daihatsu Rocky Cars & Trucks
Nov 13, 2008 | Daihatsu Charade Cars & Trucks
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
