Question about Optics
I have a David white meridian 8090 transit level.. I loaned it out n they took the scope of the base ... I need to know how to assemble it.. I tried but it still has a Lil play in it ...thanks
4 Suggested Answers
SOURCE: lost manual
Here are the Bushnell manuals-- find one similar to your telescope--
http://www.bushnell.com/customer_service/manuals/telescopes/78-9500.pdf
http://www.opticsplanet.net/bushnell-warranty.html
Posted on May 17, 2009
SOURCE: How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Posted on Aug 03, 2010
mogumbey
  • 198 Answers
SOURCE: Need a user manual for a David White ALT6-900 Transit Level
http://www.mohaveinstrument.com/NewFiles/Manuals.html I think this will get you going
Posted on Sep 05, 2014
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
How to fix crooked cross hairs on David White transit level
don't believe that is a consumer fix . has to be sent in to them
Apr 27, 2015 | David White 44 8834 1 22x Level Transit...
How to change battery in remote for a 1997 BMW 528i, when trying to change the battery and tried to see if it worked nothing happened
You have to take the old remote key back to both Mercedes or BMW to change the battery. Little profit motive there!
Mar 08, 2014 | David White 44-8871 LT8-300P Universal...
Cross hairs stick, tap instrument it corrects it
Put it on its side and bang it on a counter...not too hard now
Nov 11, 2013 | David White 44 8834 1 22x Level Transit...
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
Optics Logo
66 people viewed this question
Top Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
