Question about Car Audio & Video
Prestige platinum model aps-250-a
My alarm chirps 6 times for no apparent reason. day or night outside or in garage. how can I stop this?
3 Suggested Answers
SOURCE: problem with prestige platinum car remote starter and security system model aps-995a
IGN stands for Ignition. ie put your key in the ignition and turn it on, but dont start the engine.
Posted on Dec 04, 2009
tbreeze47
  • 3083 Answers
SOURCE: The Prestige APS 101N alarm
I couldn't find any report of this on the net, and couldn't find a manual for it, but I suspect that it's giving off a low battery alarm, or starting to be triggered by a slight movement, then shutting off when the alarm stimulus is not sustained. I would run it by a car installation facility, or Dealer Service Center to get their opinion- they deal with these items all the time.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 06, 2010
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Why does my viper alarm suddenly start chirping?
Mine does that too (chirps 8 times), every 4 to 8 hours or so (seems to be random but persistent). The alarm was installed November 2014 and I just started noticing it in May 2015, possibly because I am now within earshot of where my car is parked?
Apr 28, 2012 | Viper Security and Remote Start System...
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30...
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
Jun 23, 2017 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
Jan 25, 2011 | Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
My audiovox prestige alarm only does slient. How do I get it back to chirping ? model # aps02bt2
Simple....
1st turn the ignition key on than off
2nd within 10 seconds press and release the valet button switch 3 times.
If you did it right you will hear 1 chirp to indicatate the chirps are back to irritate and ******** all your neighbors.. just kidding. good luck
Jul 31, 2009 | Car APS02BT2 Transmitter for...
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
