Tcl l40f10f doble image
See doble image in my elementos t.v what i can do about it
First thing to try is a convergence. This may have to be done manually. Convergence is aligning the color guns so they lay on top of each other perfectly. You may have an auto converge but you will have to check in your set up menu.
May 01, 2016 | Televison & Video
Tcl lcd 40f10f
Check the antenna orientation. If it is not in correct direction, this kind of fault can occur.
Oct 15, 2013 | Televison & Video
Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
Mar 10, 2010 | InFocus Proxima DP6155 Multimedia...
Sharp ar-235 doble image in the copy
1.Might be a fuser problem. Check the upper fuser roller not to have toner on it.
2.The quenching lamp, if any, might be burn out.
Oct 19, 2008 | Office Equipment & Supplies
Projection tv
Replace Both STKs 392-020s up grade with 040s, if they are 392-110s,150s go to 180s.
Oct 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
DOBLE IMAGE
THE CONVERGENCE DRIVER CHIPS NEED REPLACED. CHECKSUPPLY SAFETY RES ARE OK AFTER REPLACEING STKs RESET CONVERGENCE. CHANCE BOTH STKs.
Sep 09, 2008 | Toshiba 43H72 43" Rear Projection...
The image looks like doble
you need new Convergence ICs which is a fairly simple repair. Post your model number and I will post the STK numbers of the ICs you need as well as a link where you can get replacements that come with free installation instructions with pictures so you can do the repair yourself.
Apr 16, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
