Question about Toshiba Computers & Internet
Bios reset Toshiba U205 S5057
Hi, I have a Toshiba U205 S5057 with a bios lock. I have searched everywhere and am unable to find a reset. I believe that the cmos battery plugs in and is located on the lower right side of mother board and has a two pin male molex connector. I removed this for two days and it did not reset the bios. Unless there is another battery somewhere which I am unable to locate, this fix is not going to work. Every thing that I've found which is very limited tells me that it's either a short across a pair of solder points or a short from ground to a solder point. If that is the case, would you happen to know where this is located on the mother board if I am right and which method to use to reset the bios. If I'm wrong, do you have any idea how to reset bios on this machine? I really need a little help before I short a chip and ruin the mother board. Thanks for any help you can provide. RC
aayushik
  • 59 Answers
SOURCE: How to reset BIOS password - Toshiba Satellite 1605 CDS
you dont have to take the battery off, just unplug the cmos connector which looks like a stereo wiring harness.
Posted on Nov 14, 2008
  • 46 Answers
SOURCE: i need to reset bios on a toshiba l305d-s5895, i
There sould be a jumper setting on the mainbaord.
Posted on Oct 30, 2009
emallari27
  • 86 Answers
SOURCE: fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Posted on Feb 03, 2010
  • 1121 Answers
SOURCE: Toshiba Satellite A55-s1066 need help Loacting Bios Chip.
you need to remove all at same time and memory modules too, and after remove the cmos battery, try to find a passw clear switch on the motherboard nearby cmos battery.
Posted on Feb 14, 2010
cirocpatel
  • 524 Answers
SOURCE: bios/power-on password unknown, toshiba satellite
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery2_bing.gif. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery2_bing.gif and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting2_bing.gif steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 05, 2010
What BIOS does toshiba have
If you are using Windows, Run (Windows Key + R or in the search when clicking the Windows icon) type msinfo32 and when you see the icon for it, open your System Information window. The BIOS information is listed under BIOS Version/Date. (I'm stating the method to find it as depending on upgrades and whatnot, the BIOS version can be changed.)
Aug 18, 2014 | Toshiba Satellite Computers & Internet
Satellite u205-s5057 freezes up when online.
Sounds like a bug. Download and install CCleaner and Malewarebytes from CNET. Run CCleaner first, both the Cleaner and Registry, then Malewarebytes on a Quick Scan. If there is a Java or Adobe Flash bug in the laptop, Malewarebytes will find them.
Your not done yet!
Download TDSSKiller for Kaspersky. You can find it on Google and at CNET. Run TDSSkiller and make sure there are no root kits. When you are done with that, make sure you have all your Microsoft, Java and Adobe Updates then Run a Full Scan with Malewarebytes.
Please post how this works out for you.
Jan 18, 2014 | Toshiba Satellite U205-S5057 Laptop AC...
Toshiba u205 - SD card won't stay in reader
Just buy an external SD card reader that plugs into one of your usb ports. You should be able to get one at any local pc shop or best buy.
Aug 17, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Hi.I just forgot my bios password.the laptop dosent allow me to change the operating disk when i turn it on.it just want a password. Model: Toshiba U205-s5022
open your laptor, plug off bios bettery, then plun in again, that will reset bios password
i hope this helpfull
please rate my answer
thanks for using fixya
Dec 09, 2010 | Toshiba Satellite U205-S5002 Notebook
Bios does not save any changes that are made toshiba sat.
Changes to Boot Order only last as long as the next boot, you have to press F12 every time to alter boot sequence.
Oct 06, 2009 | Computers & Internet
Locked out of bios on my Toshiba u205.
Synopsis: When a Supervisor password is set, access to the BIOS is restricted by default unless the Supervisor Password is entered at the "Password=" prompt when starting the notebook. However, should the User/Power-on Password NOT be set then no such prompt will appear, and access to the BIOS will not be possible.
Solution: To access the BIOS set-up routine in the above scenario it is necessary to start the notebook from cold (not from standby or hibernation) whilst holding down the "INS" key. This will force the "Password=" prompt to appear. After entering the Supervisor Password a small menu will be displayed, and one option on this menu is to access the BIOS set-up ro
Aug 12, 2009 | Toshiba Satellite U205 Notebook
Cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
May 10, 2009 | Toshiba Satellite U205-S5002 Notebook
Hard Disk Sound
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Sep 17, 2007 | Toshiba Satellite U205 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
