Question about HP PSC 500 All-In-One Printer
Paper feeder The paper feeder on my PSC 500 is not grabbing the paper...Is there something to fix this? I LOVE my old PSC 500 and am not ready to give up on it.
    Scholar:
  • 31 Answers
Hi, most printers usually have rubber pickup rollers that get worn out with time. Usually cleaning the rollers with rubbing alcohol will restore the rollers for a while. Sometimes getting to the rollers takes a long Q-tip but cleaning with a rag is best. Good luck.
Posted on Aug 29, 2007
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Paper slipping Lexmark X2470
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Apr 10, 2012 | Lexmark X2470 All-In-One InkJet Printer
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
Printer will not grab the paper HP PSC 1315 All in one inkjet
Try using a cloth (not a paper towel) with some water on it and clean the feed rollers. Also no alcohol.
Jan 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1510 printer malfunction
Open the rear cover and clean the roller with clean water. Worked for me.
Mar 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Printer not pulling paper
Check for a jam in paper feeder, look down back with a torch, open up unit and search inside, have a pair of tweezers handy as jams can occasionally be very minute and hard to grab.
Aug 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
Printer problems
I understand that you have not used it much. But you need to make sure the rollers are clean. Take it apart and make sure nothing is on the rollers. If that does not help, check on the printer and see if there is a reset button to reset the whole machine. It may be malfunctioning for some reason and this should fix the problem. If that does not help you will have to take it to a tech.
Sep 13, 2006 | HP PSC 1610 All-In-One InkJet Printer
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
