Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
Turned my pump off turned it back on allmi hear is a humming
Turned my pump off to clean the filter. Turned it back on and my motor isn't starting up just humming?
3 Suggested Answers
  • 990 Answers
SOURCE: pump does not turn on except for a humming sound and shuts off jumping the electric breaker
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
Posted on Aug 25, 2009
  • 12104 Answers
SOURCE: Motor hums, but does not start..
turn off power open access panel and check pump close water valves to pump and disconnect lines ckeck pump for debris that may be stuck in pump blocking impeller if clear than lube motor bearings and try moving impeller back and forth to free motor once free return and test pump
Posted on Apr 18, 2010
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
I shut off my pump yesterday and water shot out of the skimmer. when i turned the pump on it wouldn't work, the pump basket has water in it but it isn't pumping anything, no water coming out of...
I suspect you had air trapped in the filter. When the pump shut down, the compressed air in the filter pushed back, turned the pump backwards, and unscrewed the impeller off the motor shaft. This particular pump doesn't use an impeller screw which prevents this from happening. You will have to pull the pump apart to see if this is the cause. I have seen this happen many times.
Sep 15, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My '97 GMC Jimmy was running fine one day and then wouldn't start the next. The battery is fully charged, the engine turns over when the ignition key is turned, but it just won't catch....
TURN THE KEY SWITCH TO THE ON POSITION ,WITH THE GAS LID DOOR OPEN DO YOU HEAR THE HUMM OR WHINE OF THE FUEL PUMP,YOU MAY HAVE TO GET A 2 PERSON SO THAT YOU CAN PUT YOUR EAR RIGHT UP TO THE FUEL DOOR TO HEAR THE HUM,IF THEIRS NO HUM ITS NOT GOING TO START.THE TANK THEN MUST BE REMOVED AND A NEW 250$ FUEL PUMP WILL NEED TO BE INSTALLED.THE PUMPS ARE ALSO DIFFERENT BETWEEN 2DR AND 4DR. EBAY HAS CHEEP PUMPS 100 OR LESS.
Aug 06, 2011 | 1999 GMC Jimmy
Not getting gas to engine
Assuming you have a late model truck, when you first switch on the key do you hear the Fuel Pump "hum" (toward the back and maybe above the tank)? If not, that pump is either not getting electricity (bad fuse? or perhaps the terminals need cleaning ...or the pump, if it isn't doing anything (no humming, etc) ...then it's in need of replacement. Best of luck! You may also have a clogged fuel filter but I have no info on your truck so I'm of little to no help!
Aug 01, 2011 | Ford Windstar Cars & Trucks
I have DBSR4EB3WW model number. Last night I was drying clothes, tryed to turn dryer back on , turned the button to right to start clothes and all it would do is make a humming noise. ...
Hello Deborah, it could be a number of things, First the belt, usually if you hear a humming and the drum isn't turning, Its a broken or slipped belt, the hum you hear is the motor turning, But with no belt the drum can't turn other things that can go wrong and cause this are the safety switch located by the dryer door has failed, or a thermostat located in the rear of the machine is bad or stuck if you feel you can check these things , thats cool, just let me know you want to give it a try ,
Jun 16, 2011 | GE DBSR453EBWW Electric Dryer
My car starts and shuts off after 3-5 seconds.
with key in ON position can you hear the fuel pump humming uder the middle of car? the pump should hum for about 10 to 15 seconds,then go off and come back on when the key is turned off and then key turned back on.could possibly be a bad fuel filter, or a fuel pump going bad, it's definitly a fuel issue because it starts. try replacing the most inexpensive thing 1st. the fuel filter and then the fuel pump. hope this helps!!!
Nov 11, 2010 | 1995 Chevrolet Camaro
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
