Question about Epson Stylus Office Equipment & Supplies
Communication error occurred. Check the I/F cable connection and power of printer.
jackboy
  • 2985 Answers
SOURCE: A communication error has occurred.
A.Unplug and re connect the printer B.Go to Printers and Faxes and click on install printer. When sked for CD or go to list- select - Go to List Select Make Select Model Click OK Make it your default printer
Posted on Jun 30, 2007
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
Posted on Mar 31, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
SOURCE: Printer status -- Printer power off Communication error/printer mismatch
Had this exact problem after motherboard smoked and transferred hard disks to a new system. The printer installed fine on a different machine which was comforting, and would be a good test to run.
Turns out deleting the printer isn't enough. Wound up reinstalling the driver. That's a pretty obvious next step but the 1350W driver installer apparently does things its own way so if the windows add new hardware wizard comes up you MUST cancel it. Not sure which of these steps are required and which are not, but here's what I did to the best of my recollection ;-)
0) Turn off the printer.
1) Delete the printer (all instances of 1350W) in printers and faxes.
2) In add/remove programs delete the Konica Minolta application.
3) Reboot (this was always a key step in Win98 reality, not sure if XP requires but it can't hurt.)
4) Turn on the printer. If at any time the add new hardware wizard comes up, just say no.
5) Run setup from the driver CD. If you don't have the CD you can get it from KonicaMinolta or CNET (download.com).
6) For me it defaulted to LPT1 but I chose USB001 from the list.
7) If it throws an "error adding service" message don't panic. That may be why there was a problem to begin with (the error, not necessarily the panic.) This happened to me but clicked OK and after several seconds the installer resumed. Next thing I knew was prompting me to add paper.
The error message (for Googling purposes) was:
Error Adding Service
File: MLPTDR_Q.SYS
Dependencies: +Parallel arbitrator
Load Order Group: Extended base
dwServiceType: 1
dwStartType: 2
Hope this makes someone's day.
DaveWasHere
Posted on Aug 03, 2009
What is error 004 and what do I do about it
This error refers to the communication error between the printer and its connection. To help you troubleshoot the issue, please follow the steps mentioned below:
-Turn the printer off using the power switch located on the printer panel.
-Wait 10 seconds, turn the printer back on, and check if the error message still occurs.
-If the error persists, reseat all of the toner cartridges. For more information about reseating toner cartridges, refer to the user's guide for your printer manufacturer.
-While reseating, clean the toner cartridges with clean cloth and verify that the orange plastic covers have been removed from the developer rollers.
-Turn off the printer, and disconnect the AC power cable and communication cable (Ethernet or USB, depending on set-up).
-Remove the Imaging Drum and verify that the developer rotor frame is not bent. If the frame is bent, please contact printer manufacturer to replace it.
-With the Imaging Drum removed, Open the front cover and then push on the toner cartridge handle to determine if the carousel moves freely.
-Reconnect the AC power cable, turn on the printer, and check. If the error still occurs, please contact your printer manufacturer for further advice.
GuruAid.com
Mar 28, 2016 | Office Equipment & Supplies
Error code e0000674 solution to resolve it
an error has occured in communication between fax controll PCB and main controller PCB.Check the connection of the cable between the fax controll PCB and main controller PCB.rEPLACE THE rom dimm of the fax control PCB.Replace the fax controlPCB.Replace the main controller PCB.
Jan 29, 2015 | Canon ImageRUNNER 3570 Copier/Printer
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Dec 14, 2010 | Epson Stylus Pro 9600 InkJet Printer
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Ink is out and communication error has occured?
Sounds suspiciously like a Windows problem to me. It may be worth trying to reinstall the printer. Delete the old one in 'Printers', and then reload from XP or Vista, or shove the printer CD-ROM in and reinstall.
Jun 27, 2009 | Epson Stylus Photo 950 InkJet Printer
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
image processor PCB was detected.
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
Aug 05, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
2,865 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
