Question about Bang and Olufsen Beotalk 1200 Digital Answering Machine
Bang and olufsen BEOTALK 1200
I have a B&O 1200 Answering machine. It does not seem to be accepting teh commands when I set various functions, and althoguh it anticipates the call and displays the caller number, the answering machine does not actually kick in and allow the caller to leave a message. The machine then displays that there is a message left, but when you press news, it beeps 3 times with no message left. Anyone come across this? My local B&O dealer has been no help
  • 2 more comments
  • Anonymous Mar 07, 2008
    Unable to establish a recorded outgoing message after reinstalling the machine on the wall.
  • beocomtara Jun 06, 2008
    i know this is an old post but we have exactly the same problem, we have recorded a message and it is activated <-> appears top right of display, when you ring the number it displays the callers number starts flashing '1' as though it has answered it but doesnt play the greeting or allow the caller to leave a mesage, i've read the manual several times and no joy. Tried all sorts of configurations but still no luck. please help! Its an analogue answering machine and i'm wondering as we are with virgin media if our phone line is digital? is there anyway to make it compatible if this is the case?
  • mikespace Dec 23, 2008
    Hi...my beotalk 1200 seems to have given up.. recorded new message, reset clock,but will not answer incoming calls with message, clock resets itself to any old time and other functions unreliable.. my B&O want £60 notes just to look at it! Does this mean a bin Job for B&O after only 3 years??? -also recently on Virgin I may add ( is the operating line voltage the same?) can you get Circuit diagrams for this..?
  • AdieW Mar 02, 2009
    I have the same problem I have in ON, I have set the Message and I do not have silient Answer on. The answer phone rings once then drops the call with no chance to leave a message, please help?
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Posted on May 03, 2008
Bang and Olufsen Beosound 2000 directions
This is described in the owners manual. If you don´t have it, ask here, they can get you every Bang + Olufsen manual
Sep 04, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I recently purchased a Panasonic DVD Recorder Model DMR-EZ48VEB to use with my Bang & Olufsen Beovision 8902 TV. Having set up the recorder the DVD remote control would not work because the DVD...
You said you have the operating instructions, try this,instead of doing the manual entry of your code, try using the CODE SEARCH method for each one....hope this was helpful.....
May 23, 2010 | Televison & Video
Hi, I have a B&O MX7000. The problem I have is that I turn it on in the morning and after about 2 mins it goes into standby with little cracking noise and cannot be used again till the next day. Am i...
hello,yes you are to look at the dry joint connectors,that is where the fault came from.i would suggest you visit an authorized repairer to help you give a proper check on the dry joint if you arenot electronically inclined so as not to compound the problem.
Thanks for using fixya,
Take care.
Apr 09, 2010 | Bang and Olufsen Beotalk 1200 Digital...
Beovision MX 7000. Crackling noise emanating from speakers followed by picture jump. This happened on a couple of occasions then one final crackle, slight burning smell, no picture - power light pulsing...
Check 2 areas,capacitors c102 c103 c104 for burnt joints all in deflection cct.and burnt connector at scan coil at tube end,if its this second problem c102 and line output transistor may also be faulty.
Mar 12, 2010 | Bang and Olufsen Beotalk 1200 Digital...
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Manual/user guide for beotalk 1200
Hi.You can find the manual:
http://www.bang-olufsen.com/
user-guidescat=Telephones&prodid=134&typeid=1
Michael
Sep 30, 2009 | Bang and Olufsen Beotalk 1200 Digital...
Beotalk 1200answering machine
Try joining the company's website. You should then be able to download the manual.
http://www.bang-olufsen.com/page.asp?ID=119&cat=Telephones&prodid=134&typeid=1&bhcp=1
Feb 25, 2008 | Bang and Olufsen Beotalk 1200 Digital...
Registering handset to base
I reviewed the user guide for that model, and I only see that it is an answering machine. I may indeed be wrong, but is there a chance you have a different model unit? Regardless of the model, normally you have to put the base in registration mode simultaneously when the handset it put in registration mode like you were doing before. If you do not have the user guide you can join Beoworld.org for $27 a year and download it for "free". I am curious to know if you have a different model or if you can register cordless handsets to the 1200. Maybe you can post an update. Just learning this model myself. Good Luck
Feb 01, 2008 | Bang and Olufsen Beotalk 1200 Digital...
Bang and Olufsen Beotalk 1200 Digital Answering Machine Logo
1,916 people viewed this question
Top Bang and Olufsen Lands Phones Experts
Marvin
Marvin
k24674
Are you a Bang and Olufsen Lands Phone Expert? Answer questions, earn points and help others
