Question about Garden
Huskee supreme 5400
How do I change the Drive belt on the Huskee Supreme slt 5400h
  • 376 Answers
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Posted on Jul 06, 2009
lemmingleejn
  • 173 Answers
SOURCE: huskee supreme slt 4600 2007 model no 13ax775h730
Perhaps, there is a problem with the tensioner pulleys.
Or as I have recently discovered, when changing drive belts/cutter belts,
They're ever so slightly, not the right length.
Or even, not the right thickness.
But if you can check the tensioner pulley springs, to make sure they tighten up correctly, that might give you a clue as to the problem.
Have fun.
Posted on Jul 24, 2009
Dolfoff
  • 148 Answers
SOURCE: I have a Huskee Supreme Model # 13AX605H730. I have
According to MTD Parts Lookup:
The correct UPPER belt (referred to as the PTO belt and runs from engine to deck) is part # 754-04122 (Also available as 954-04122...in which only the packaging of the part makes the first digit of the part number change. The two belts are identical.)
The correct Description is:
[ Belt, V-Type, A x 90.24 ]
What that means in plain English is that this is a 1/2 inch wide V-Belt with an Industry Standard "A" cross sectional profile. The more important info would be that it's 90.24 inches long.
As for the "Deck Belt" (the lower belt that runs only from blade to blade to blade) it is listed as part #754-0349 or #954-0349 (again, identical belts, different packaging).
A very common problem we see in my shop is that the front pulley (the one directly attached to the engine) shows signs of separation at the weld and the grovve of the pulley becomes wider, therefore making the belt "act" like it's longer because it runs deeper in that groove.
Reply by using the "Add Comments" section if you need any futher info. I'd be glad to offer other possibilities for these symptoms you've described.
Hope this helps,
Dolf-
Posted on Oct 17, 2009
  • 6468 Answers
SOURCE: the drck wont raise up on my huskee supreme slt 4600
look to see if the lift cable broke or clips fell off
Posted on Apr 27, 2012
kevin_getz
  • 1031 Answers
SOURCE: What type of trans fluid in a huskee slt 5400h?
You can substitute with 15-40 motor oil.
Posted on May 21, 2012
2006 huskee supreme slt 4600 keeps blowing fuse
Make sure the battery is not shorting out against anything.
Jun 17, 2013 | Cars & Trucks
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
Huskee Supreme (MTD body) loose steering, looks like some spacer or grommet is missing, but can't find in parts diagram
?l=mtd&p=76902073%5c0001&nd=0&z=30
OK THE PART YOU NEED IS PART # 37 PART # 941-0656A ITS CALLED A HEX FLANGE BEARING
Nov 03, 2012 | Mtd Garden
May 20, 2012 | Mtd Garden
The drck wont raise up on my huskee supreme slt 4600
Apr 26, 2012 | Garden
Hope this helps,
Dolf-
Oct 17, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Huskee supreme slt 4600 2007 model no 13ax775h730 serial no 1b087b70102 if i am on flat ground it seams to go just fine but up a small hill does not want to go all belts are new need help just bought it...
Have fun.
Jul 22, 2009 | Mtd Garden
Jul 06, 2009 | Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
