Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Recover data acomdata external hard drive - Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
SOURCE: ACOMDATA HD080U2FE-72 External Hard Drive
my final solution was to remove the drive from the housing and install it as a slave in the main case. The computer is operating Windows XP and instantly recognised the drive. Works fine, all of my data is there. No problem now. This approach will not help laptop users but they might try removing the drive from the ACOMDATA housing and installing it in another housing.
redrippervf1
Posted on Sep 17, 2008
SOURCE: acomdata hard drive doesnt show up on my computer
I have the 250 GB Acomdata drive. Had the exact same problem--computer would not recognize drive; blue light on drive lit and drive making a slight whirring/clicking noise. I read somewhere that some people that have had this problem have found the problem is with the USB interface between the drive and case, NOT with the drive itself. I took the drive out of its case and installed it in a desktop computer and was able to get all of the data off of the drive.
Posted on Dec 31, 2008
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
Crankstart
  • 696 Answers
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
Geekinator
  • 183 Answers
SOURCE: External Hard Drive not showing on My Computer? [URGENT]
Hello there Mansoor.
First, I have to commend you on how clear and extremely well articulated your problem is presented. You give every detail necessary to grasp your current situation. Good job! I can also clearly see you're at least a fairly proficient user. I only wish I'd reviewed your question before now, so I could have replied sooner. That notwithstanding, here's my GEEK-steer ...
Good job testing the drive against other "known good" systems. Because (as you probably already know) based on that, it's a virtual certainty it's the drive itself that's the source of the problem (UNLESS you used the same USB cable in all tests ... rule that out by using a "known good" cable). Its trouble could be caused by any number things [e.g., deleted partition, virus related, "sector" (file/folder structure related) errors, etc.]. At this point you've utilized all the tools that Windows avails you to work this problem (e.g., you obviously can't perform a Windows "chkdsk" on it unless there's an assigned and known driver letter, "Disk Managment" was no help, etc.). We therefore need additional software tools in order to proceed further.
Per the manufacturer's webpage, "Acomdata does not have any Windows XP, Windows Vista or Mac OS drivers because all products use the built-in driver support already supplied by the associated Operating System". Therefore, they design all their devices to be supported by Windows' database of generic drivers. However, here's their offered driver package for "All Platforms". It's a long-shot, but it couldn't hurt to start by giving this driver a try (you can always "Roll back driver" from within "Device Manager" if necessary).
== CAPTURE AN IMAGE BACKUP ==
If, as you state, data recovery is of the utmost importance, then I would strongly advise your very first objective to be (if at all possible) creating an image of the problem drive, then backup that image onto another drive. I would do that FIRST to lock in it's current state as an insurance policy, BEFORE I ran any testing/diagnostics, or attempted any alternate means of data recovery. Keep that image intact throughout this process until resolution. There are several disk image "Backup Tools" (e.g., "DriveImageXML", "Acronis True Image", etc.) in "Hiren's Boot CD" you can use to accomplish this.
== BREAK OUT THE TOOLBOX ==
Refer here for complete list of its available tools. There are far too many to cover in any detail here. Particularly when the nature of your problem is yet known, as each may, or may not be THE one for the job. However, you can simply Google each to obtain background and usage instructions. Also, tools reside in either the DOS or mini-Windows boot portions of the CD, as some are DOS executable and some Windows. You may have to venture into both until you find the tool that works for you. I know there's a lot in that puppy, but that is intentional because it's a good thing ... affords wide range of choices/options.
== HOW-TO CREATE 'HIREN'S BOOT CD' ==
  1. Download "Hiren's Boot CD".
  2. Extract/unpack/unzip/decompress (<-choose your term, they all mean the same thing) the .ISO disk image file ("Hiren's.BootCD.#.ISO") located within the downloaded "Hirens.BootCD.#.zip" archive file (where # = version of Hiren's).
  3. Burn the disk image to a CD using whichever capable disk image burning software (e.g., Nero, Roxio, etc.) you may have. Don't have one? Then download and install the very capable, yet lightweight FREEWARE "imgBurn"
Burn the extracted .ISO image file ("Hiren's.BootCD.#.ISO") to CD using imgBurn:
  1. Insert a blank disk (R/RW) into your disk burning capable CD/DVD drive.
  2. Launch "imgBurn", then select "Write image file to disc".
  3. Browse for and select the "Source" .ISO file above.
  4. Ensure the applicable disk burner drive is selected as "Destination" (you may have more than one).
  5. Click the burn icon.
  6. When burning completes, close "imgBurn".
== RECOVER THE DATA ==
Next I would attempt recovering the data using any number of Hiren's "Recovery Tools" category of tools (e.g., "ProSoft Media Tools", "GetDataBack for NTFS", "TestDisk", "Ontrack Easy Recovery", etc.). Many of these include diagnostics/repair facilities you can use in the course of your recovery efforts.
== RECOVER/FIX THE DRIVE ==
Then once/if you've successfully recovered the drive's data, you can (if applicable) use any number of Hiren's (hard-drive related) "Testing Tools" and "Hard Disk Tools" categories of items in order to fully test/diagnose and hopefully recover the drive to working order.
TIPS:.
  • Be aware that you MAY discover you'll HAVE to perform testing/diagnostics/maintentance related actions on the drive first, just in order to get it into recognizable shape for any of the drive image and/or data recovery related tools to perform. That's OK, 'cause "you gotta do, what you gotta do".
  • "Partition Find and Mount" might be particularly helpful in recognizing, then mounting the drive
I apologize in advance for any logic-sequence or grammatical errors this reply may contain. I culled together a few differing draft stage portions of some "Tips & Tricks" I'm intending to post in the near future.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 09, 2009
My hard drive is blinking
If this is an USB external hard drive the try connecting it to another computer.
If it does not work then the hard drive is faulty. All hard drives will eventually fail.
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Mar 30, 2013 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Trying to figure out if my acomdata 80 GB Hard Drive still works, its been along time since I"ve used it, was wondering if I got the fire wire connections right, Are you supposed to use two fire...
just one firewire cable will work.
if the unit doesn't power on you can pull the hard drive out and put it in another external hard drive case usb/firewire/sata.
if it doesn't work then the only option to recover the data is to send it to a 3rd party hard drive recovery.
Mar 04, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I recently tried to access data from my Acomdata HD500 UF only to find that my Mac no longer detected it. The blue light comes on, but no fan sounds. Is it dead? Can I recover my old family photos,...
the hard drive may be dead.
stores like best buy offer services of data retrieval, although success is not 100% guaranteed, and these services generally are not cheap.
Feb 28, 2011 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata HD08u2fe42 external drive, drive will not
You should probably take the drive to a recovery company. It sounds like there is a hardware failure on the drive that has to do with the track servo and it is unlikely to be fixed externally.
If the data is critical, take it to a professional data recovery company.
Nov 20, 2009 | Computers & Internet
Acomdata 640GB External HDD problem.
I'd recommend that you use some data recovery software. You may try asoftech data recovery that helped me before.
Feb 22, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
I/O Error on Acomdata External Hard Drive
Go into Control Panel/System/Device Manager and look for yellow exclamation marks. Delete any you find. Reboot your computer. Connect the external hard drive and turn it on. Let Windows discover it. If it asks for the driver, put in the CD that came with the drive.
If this will not works means there is some problem in your HDD partition and you need to format them...
if you donot want to lose any data then use any recovery software to recover data from your HDD.
Good Luck!!
Thanks
Oct 14, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata is Kaputz
The clicking and running noisy is a bad sign. The actual drive in the unit has failed. Sometimes the controler board in the external case goes and you can simply replace the case for $10 online and be up and running. I'm a data recovery expert. If you have irreplacible data on the drive that you need recovered let me know. I'll recover the data for you I have all the required equipment. The only thing you need to pay for is the exact same make and model of the internal HD in the case and postage both ways. I'm retired and I do this for a hobby now. Let me know if you need me services. Hope you find this helpful. My e-mail address is geokohler@gmail.com if you want to send me your number and we can discuss the procedure.
Thanks,
George
Sep 24, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
65 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
