Question about Kenmore 16879 Built-in Dishwasher
Power to Front Control Panel
After replacing both circuit board and door switch I still do not get any response (power) indication on touch panel.
  • geehaa Aug 29, 2007
    Events leading up to zero response or no power indication on touch panel was incomplete cycles on intermittant basis (not often - two or three times over previous month). I definitely have power coming to unit as measurable by the appropriate AC voltage at the door micro switches. Intend to return new board and have the old board tested against the remote possiblility of new board being being bad. If the boards are good is it possible the touch panel set up is faulty?
  • 640 Answers
YOU DEFINITLY HAVE POWER COMING TO THE UNIT?IS THERE A TRANSFORMER?IF YOU HAVE THE CORRECT VOLTAGE AND THE KEYSWITCH (TOUCH PAD)PLUGS INTO THE BOARD YOU REPLACED THE KEYSWITCH IS BAD.HOW DID THE PROBLEM START?
Posted on Aug 29, 2007
  • anthony james
    anthony james Aug 29, 2007
    if theres no transformer stepping down the voltage to the board thats what i would say but you can get brand new boards that are bad couldnt tell you how many times it happened to me.
SOURCE:
Where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Why is my GE front load washer is non responsive. The control panel went blank. Not a power issue since the outet is good. Model GBVH5140HWW
It could still be a plug or wire problem but if not a power problem inside the machine or a printed circuit board or other internal failure. It will not be possible to diagnose the problem without a lot more inforamtion.
Sep 12, 2014 | Washing Machines
Error code 41
The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the door lock/switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly
to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock/switch assembly out of the front panel then
disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly (part #131763202) to address the problem if the washer works fine with the door switch bypassed. If not, replace the control board.
Jul 18, 2011 | Frigidaire ATF6700FS Front Load Washer
Oven door wont unlock/open
E1 and F1 error code indicates a faulty ERC board. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing. Gain access inside the control panel.Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.Turn the power back on. Wait for an hour to see if the code comes back (usually accompanied by a beeping sound). If code comes back, replace the ERC. If it does not, replace the touch pad.
Thank you !!
Jun 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
MDBH945AWW maytag dishwasher panel lights will not light up. checked breaker and was not tripped. Hardwired circuit. will check tomorrow to be sure power gets to dishwasher. Suspect have panel control...
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Dec 23, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
Lx30h hobart dw. booster will not turn on. element good,hi-limit is good, changed temp probe, still no power to contactor
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Jul 04, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Kenmore 16879 Built-in Dishwasher Logo
77 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
