Question about Refrigerators
Kitchenaid KTRC22E Doesn't seem to be consistently cooling. Do the number settings on the "cooler/warmer" dials mean lower numbers reflect cooler setting or visa-versa/
4 Suggested Answers
SOURCE: With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Posted on May 02, 2009
  • 415 Answers
SOURCE: in the refrigerator the temperature settings the
the higher you set the frig the colder it is to get
Posted on Sep 09, 2009
  • 403 Answers
SOURCE: The number on the dials..is
The lower number is for warmer, higher number colder, unless indicated otherwise. May need a thermostat. Whats the model of your refrigerator?
Posted on Feb 23, 2011
Hi my fridge is heating up. What setting on the dial makes it cooler. A higher setting like 6 or lower like 3?
The lower the number on your fridge will make it cooler, but if it is still not cooling done after an hour or so, after resetting the dial, you made need to contact a technician to check the cooling system on the unit.
Jan 21, 2017 | Refrigerators
Not sure which way I turn the dial to make the fridge and freezer cooler
The lower the number the cooler the setting. Standard settings are left for lower right for higher, left for cooler right for warmer. good luck
Jan 21, 2013 | GE GSH22JFT Side by Side Refrigerator
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
The number on the dials..is the lower number for cooler and the higher number for a warmer..Everything is freezing in my "small-dorm size refrigerator"
Feb 23, 2011 | Magic Chef Refrigerators
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
You have it right. The number you set is the temperature it will give you.
Higher number, Warmer. Lower number, cooler.
Good Luck,
Wayne
Aug 14, 2010 | Honeywell ER150B Air Conditioner
I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
Aug 09, 2010 | Samsung Refrigerators
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
