Question about Garden
Swisher zt 60 mowing deck removal
How do you remove the mower deck for maintenance?
2 Suggested Answers
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
What is the best way and how to remove mower deck for cleaning
Why do you think you need to remove the whole deck just to clean it and sharpen the blades? What kind of design would that be, manufacturers wouldn't sell too many lawn mowers if you had to remove the whole deck just to do what you're asking
Sep 15, 2014 | Swisher T14560 T - 60" Trailmower with 14...
Swisher xzt 60.. while mowing grass pushing the arms forward the blades slow way down.. how can i fix this issue? I just put new deck and engine belts on..
Swisher is proprietary in the service arena for information. The most common cause of the issue that you are describing is belt slippage. This could be due to oversize belt length. improper tension, loose pulleys etc. Also when you look at an area that you have mowed after one day, if the tips of the grass are yellow, the blade is not sharp enough.
Jun 21, 2014 | Garden
I need a cable for swisher mower 60 in deck , cable supports cutting deck and helps level deck
Buddy of mine is a Swisher dealer give him a call 1- 920 - 841-7654 This is a Wisconsin number Im sure if he has one he can ship it or give you a name of someone closer.
Apr 10, 2012 | Swisher Garden
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Deck plugs up, will not discharge, especially in taller grass, tried different blades nothing works.
the one thing I have noticed with my swisher 60" is my grass have to be dry or the deck will clog and because of the mulching deck it is not recommended to cut tall grass.
Dec 26, 2009 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
