Question about M-Audio StudioPro 3 Computer Speakers
Connect tv studiopro 3 speakers - M-Audio StudioPro 3 Computer Speakers
No sound in right speaker
wire must be damage...check that it must not be put in wrong output pin...
Jan 19, 2012 | M-Audio StudioPro 3 Computer Speakers
Where do I get a volume control switch for a M-Audio studiopro 3?
@ Radioshack PN 271-0002 Volume Control with Push Switch, it will fix the speakers but make them MONO, so you need 2 of them to make it stereo. I recommend 2 cause this speakers have the volume distribution problem from factory.
Jan 02, 2011 | M-Audio Studio Pro 3 Professional Desktop...
Whats the AC SELECT on the backside of the speakers? I turned it on one time and now there is no sound from the speakers even if i turn on and off AC SELECT!
If these run directly from the mains, and you're in a 220v or 240v country, then you probably switched the power supply to run from 110v instead, and overloaded it. If you're very lucky, the fuse has blown, but talk to a repair shop about this and see whether they think it's worth fixing.
Jun 26, 2010 | M-Audio StudioPro 3 Computer Speakers
What do i hook the speakers up with they only came with one cord what else do i use
The one cord will be connected to the computer or any audio output device. The speakers will be connected together through a cord.
Apr 29, 2010 | M-Audio StudioPro 3 Computer Speakers
Where can I find replacement parts for these speakers?
Your best bet is to replace them for $79
http://pro-audio.musiciansfriend.com/product/MAudio-StudioPro-3-Professional-Desktop-Audio-Monitors?sku=603709&src=3WFRWXX&ZYXSEM=0&CAWELAID=26047440
Otherwise you are limited to being able to replace with the same size but not the same part. In other words, no one makes exact replacement parts for those.
Mar 14, 2010 | M-Audio StudioPro 3 Computer Speakers
Buzzing
bad amplifier or input has bad ground conection or positive conection
can you describe if its only one side or comming out both?
Oct 16, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
Stopped working
Sorry I don't have a solution, but the speakers have done the same with us. Power comes on, some sound like the wire shorting out, but otherwise no sound. Tried different connection wires, different computers (mac and pc) but no go on any of them. So, I also don't think it has anything to do with you deleting some files.
May 11, 2008 | M-Audio StudioPro 4 Main / Stereo Speaker
Cant get monitors to work
check all powre cable properly 1st ,,,
if no diplay..then u r moniter is ded & contact ur computer dealer imideatly...
best regards & best of luck..
Oct 12, 2007 | M-Audio StudioPro 3 Computer Speakers
M-Audio StudioPro 3 Computer Speakers Logo
15 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
