Question about Fossil AM Watches
3998 861001 My husband just stopped working. He thought it was the battery , so took it to get a battery and was told it was it wasnt the battery and suggested to on a fosssil website. I cant seem to get any answers , help!
Hi I have a Citizen Watch Promaster jP1010-51w. Today It stopped working... I took it to a shop nearby to change battery, but he told me that the battery is ok and the watch itself has problem .. please...
Hi, I have to change my battery a few days ago, and The jeweller tell me the same as yours. You have to read the manual ... Once the new battery is installed, you have to open the button that is used for analogic command. When done, you must press a few second the three others button to reset the digital part ... That is what I have done with mine, and it works perfectly today ...
Oct 11, 2012 | Citizen Watches
Dull digits
Time for a new watch if it wasnt the battery.
Aug 12, 2012 | Suunto X-Lander Wrist Watch
L have Anne Klein watch and it stopped working, took it to the repair shop and changed the battery and the repairer told me it uses battery no. 317, it didn't stay long before it stopped working...
look for another watch service center, or bring it to the authorized distributor of your anne klein watch. they have what you are looking for. i hope this will helped you.
Sep 05, 2011 | Watches
I hav a casio edifice module no. 4389. i took it to the shop to get the battery replaced yesterday and when i got it back the 1/20 hand for the stop watch now runs upside down and the second hand sits on 4...
Wow. The person who did your watch does not sound like they were qualified to do so. I would go back and see if they can send it for repair as it was their error. If not, you will have to send to casio yourself. Sorry. Best option there is. Contact them at:
http://www.casio.com/support/helpdesk/
Good luck.
Aug 11, 2010 | Watches
My swatch model is swatch irony YSS112G. It stops working and when i took it to swatch shop the assistant told me its due to the mechanical problem since a new battery was restored. i was told that it was...
mcdevito75 here, Once any Quatrz mechanism goes, it"s ususlly gone. New replacement Quartz mechanisms are sold but just the mechanism itself could cost $30.00---$70.00 then the labor to have it installed, A Swatch watch is a COLLECTABLE item, it may be worth the expense of a new Quartz Mechanism, spaek with the watch shop about details.
Jun 27, 2010 | Watches
Setting instructions for breitling b-1
Try their local service center. Go to http://www.breitling.com/en/index.php#/home/ and click on "service centers" to find the address.
May 19, 2010 | Breitling B 1 Watch 755
Hi, my husband has a Tag watch which worked fine the first 1 1/2 years or so that we purchased it. After that time, it stopped working and won't start back up. We've changed the battery several times which...
There are several things that could be causing this. First is that if the person replacing the battery did not know what they were doing they could have damaged the movement. One of the most common parts that get damaged is the coil. These are wound with wire thinner than a hair and so sliding anything across the coil can damage or break it.
Another common thing is the contact for the bottom side of the battery gets pushed and bent out of place. Most times this can be straightened out. But there are times when it has to be replaced.
The circuit could be bad or the whole movement may need cleaning.
Hope this helps,
Ken
Yellowstone Watch Inc.
Sep 30, 2009 | Watches
Repair location in my area
Try AWCI.com for someone in your area. I recommend a good watchmaker even for a cell replacement, they will usually clean the case and band, do a consumption check, a min run voltage test and a water resistance test and new seals to keep watch fresh.
Jun 13, 2009 | Wittnauer Laureate 12R12 Wrist Watch
T-Touch Pressure stopped working after battery was replaced.
A new watch is the answer, mine gave up after 4 years of service, and I've been told to find a new watch.
Nov 08, 2007 | Tissot T-Touch T33759851
Watches Logo
63 people viewed this question
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
