Question about Kenmore 420 Series Water Softener
How do i set up my kenmore mod.625.3485000 softener
Water pressure has dropped over time. when softener is bypassed, water pressure is fine
A inline water softener functions similar to a filter. When a filter become clogged it restricts water flow. Perhaps this is what is happening with the inline softener unit. Try changing to a new unit.
Dec 21, 2015 | Water Water Heaters
The waster Softner does not regenerate on its own?
Hi Pam,
Did you just install this ? If not, how old is it ? This is a metered water softener, and if it is not counting gallons, it will never regenerate. To check this, press and hold the SELECT button for 3 seconds, and turn on a faucet. This will show the counting of the water. If it is not counting, there may be debris in the meter turbine, or it is plumbed in backwards.
May 27, 2015 | Kenmore 420 Series Water Softener
Culligan water softener 01014042
IF you are unsure about working on this ,then maybe you should get Culligan to send out one of there techs . I did phone a tech line for mine they where very help full and we solved the problem over the phone . Try the help line first nothing lost on a phone call .
May 16, 2017 | Water Heaters
Kenmore Water Softeners Model 625388270 Serial 12756 - Water above the salt level. I have cleaned the venture nozzle. Did not help
On this model, the problem is usually the rotor and rotor seal. When they wear, they don't let the softener create a vacuum to pull the brine water from the tank. This is a fairly complex repair. I don't have a service manual for you. The parts are available from Sears. I know this is not much help, but I've worked on hundreds of these and this is the problem 98% of the time.
Aug 05, 2013 | Kenmore 420 Series Water Softener
Error 3 on screen
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Jul 14, 2013 | Kenmore 420 Series Water Softener
My water heater pilot light will not stay lit
1) Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake located on bottom of heater of American, State, Craftmaster, Reliance, Whirlpool, Kenmore
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
3) Gas control valve thermostat might be bad.
Dec 06, 2012 | Whirlpool Water Heaters
I have a GXSF27EO1 water softener serial # LF102017B that makes a strange moaning sound frequently and I don't know what causes it, can you help me? Thank you, Don Kneebone Email donk98926@hotmail.com
That typically means the softener is in a regeneration cycle. When the valve is switching cycles it quite frequently will have the noise you describe. The regeneration cycle should be set for 2am.
RJ
Mar 09, 2011 | General Electric GE SmartWater Household...
Kenmore dish washer Mod:3631656990 S/N RM306233R. When i turn it on the washer fills with water but does not continue to the next cycle. At that point I have to open the door and manually empty out the...
Hello, Down at the base of your dishwasher is a screen filter, that if you take out and clean it will then drain. Think of it like a air filter on a car. In your case it is clogged. most the time it is clogged with food and debre. Mike
Feb 17, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Kenmore 420 Series Water Softener Logo
Top Kenmore Water Heaters Experts
Dennis
Gene Haynes
Tom Chichester
Are you a Kenmore Water Heater Expert? Answer questions, earn points and help others
