Question about Pioneer Audio Players & Recorders
HiMy Pioneer VSX-827-K HDMI output stopped working while playing music, any reason for that, should I get it replaced under warrenty?
No communication between the HDMI output and the TV, I have swopped cables, did not fix the problem
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
SOURCE: Pioneer VSX-AX4AVi-S HDMI connection to
found solution myself, will post shortly
Posted on Mar 16, 2009
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
I have a pioneer VSX-822k receiver. My older Runco CL-710 projector with DVI will not display anything from the Pioneer's HDMI output. (using a monoprice HDMI to DVI cable designed for this) The sourc
it is not compatable with 1080p,it says so on pg 17 of the projector manual,This unit is compatible with the following computer resoultions: 1280x720, 1024x768, 800x600, 640x480,you cannot use it with the receiver unless you use rca cables http://www.projectorcentral.com/pdf/projector_manual_2126.pdf
VSX 822 5 1 Channel 3D Ready Receiver
Oct 18, 2014 | Audio Players & Recorders
Pioneer av no hdmi output after power surge
internal fuse was blown check motherboard if you know how to open panel if niot take to technician
Feb 26, 2014 | Pioneer VSX-821-K - 5.1 Channel A/V Home...
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Why will my pioneer bdp-lx70 play only cd's and blu ray discs but not any ordinary dvd's ?
Check and replace its laser pickup unit. If you wish to get some details; check the site linked here. Pull up older posts.
Nov 26, 2012 | Pioneer BDP-LX70 Installed
How do I connect my pioneer vsx prologic receiver to my hdmi plasma tv?
If the tv has normal stereo outputs, you will use those. if it only has a digital output, your best option will be to buy a new receiver.
Feb 20, 2011 | Pioneer VSX-454 Receiver
I have a Pioneer VSX 52TX receiver. I would like to connect the Playstation 3 using HDMI to the receiver and then output to the Panasonic Viera TC-P58V125. The receiver does not have HDMI but does have a...
Hello a1v.... You will need a DVI to HDMI adapter, available at Radio Shack, Walmart, on the internet. This item is usually about $6.00.
Joe
Thanks for choosing Fixya!
Dec 29, 2010 | Pioneer VSX-52TX Receiver
Pioneer vsx-819H: MCACC setup won't display on tv
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Sound on cd but not on any other input
i have the same problem myelf and i just solved it...check the audio output from your video player..it has to be set to hdmi or whatever you are using for music output. mine works awesome again....
Aug 30, 2008 | Pioneer Elite VSX-9100TX Receiver
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
