Question about Garden
Ruger sr-45 recoil spring installed backwards how do i fix
The recoil spring was installed backwards and the slide was put back on but now i cannot get the slide back off so i can turn the spring around. The slide wont slide at all now its stuck .
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Posted on Sep 05, 2009
  • 302 Answers
SOURCE: rewind a recoil starter spring
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Posted on Sep 26, 2009
  • 35 Answers
SOURCE: how to put a recoil spring back in
HAhaha, oh this is so funny to me cause i suffered with the same problem, you have to grip the spring with needle nose pliers and wrap it tightly back arround, gripping the new layer every revolution, it sucks i know, then VERY CAREFULLY place it back it the spring retainer
Posted on Feb 19, 2010
dontbother10
  • 2220 Answers
SOURCE: Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
HOW TO REPLACE RECOIL SPRING IN FG110
the rope probably has broken at some point and they did not relode spring enough take the take the spring housing off remove the rope relode spring stick a screwdriver in it to keep it there put rope back on pull screwdriver out put it back on
Apr 26, 2015 | Honda FG110
How do I put a spring back into a mountfield sp544
sp544??? is it a 534 or 454 possibly? either way i think they have mountfield rv engine,you will need to remove the recoil housing assembly,remove the rope pulley (think the centre pulley screw is left hand thread) then if the recoil spring is undamaged you can wind the recoil spring back into the recoil housing
Mar 10, 2015 | Garden
How to remove a stuck slide from a pistol
most slides work the same on automatic what gun are you working with you are allowed to say on here ,
Nov 03, 2014 | Optics
My weedeater pull rope won't retract back inside when pulled to start, how do I fix this?
Spring is likely sprung out of the recoil. Take the recoil apart, rewind the cord and turn it enough to put some tension on it. Then put the cover back on.
Oct 04, 2014 | Troy Garden
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
How to repair a ruger air hawk .177
well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
Trying to put recoil back together, how does spring go
There is a groove where the entire plastic case around the spring will go. It will only fit one way. Be careful when installing the spring, if it gets lopsided. IE. Part of the spring sits on the groove for the spring housing and the rest of the spring housing fits into the the groove, the spring will come out of the spring housing.
Oct 20, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
How to put together a toro recoil
first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
Jan 14, 2010 | 2005 Suzuki RM-Z 450
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
