We have 2 door upright refrigerator/freezer. For the last 3 days the top half of freezer side is not cold enough. The bottom half of it is cold like the refrigerator. However in the refrigerator side the top half is not cold at all but vegi in the bottom are frozen. We bought it in 2001. Please give me some suggestion.
SOURCE: G.E SxS REFRIGERATOR
Ice maker works- door water dispenser does not- light comes on when dispenser is pushed.
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
SOURCE: ge refrigerator is not cooling
you have a defrost system problem. first thing you will want to check is the defrost heater. remove two screws holding it in at bottom of evap coils. You will need and ohmmeter to check resistance through the heater. (be sure to unplug unit first) Also look at your defrost termination (located at the top of evaporator) and see if it looks popped out. 19/20 times one of these two things will be the problem.
Testimonial: "great help"
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
