Question about Sole Fitness Exercise & Fitness
Sole S77 treadmill makes a "chugging noise" while being used
Purchased December 2010
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my sole treadmill turns my in line light times on
Dear Sir:
Watch this video:
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www1.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
If I can undertand very well, the problem is intermitent.
a) Check the power cord,( some wire is broken internal)
b) Look for cool solder ( re-solder)+loose connections cause intermitent operation!
c)Inspection the breaker, for loose connection, test the breaker.
d) check the transformer as indicated above.
e)and finally check the power supply after the transformer: a) resistor b) capacitors c) diodes, all this component can be loose, bad solder or cool, or broken, or short, open, or shorcircuit.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 29, 2011
  • 691 Answers
SOURCE: sole treadmill keeps shutting off and display code reads
sounds like overheating or memory issues. could simply be a bad connection somewhere. If the time it takes to shut off remains pretty constant then I'd suggest a capacitor on the electronic circuit board is on its way out.
Posted on Jan 21, 2012
ercupa190
  • 12223 Answers
SOURCE: SOLE F80 treadmill makes a audible
Dear Sir:
Sound like metal touching metal, could be roller bearing or bearing main motor.
You have 2 options: 1) Do it yourself or 2) Call to service Tech.
God bless you
Posted on May 23, 2012
Testimonial: "Thank you so much! I have a service tech coming out next week to take a look at it."
ercupa190
  • 12223 Answers
SOURCE: my sole treadmil makes noise when changing levels
1) Lube the deck belt, very well, maybe you have WORN deck belt, time to replace, this happen because the lack of maintenance schedule.
2) LUBE the roller bearing TOO.
3) Measure the input voltage motor, if there are voltage , the motor NEED repair.
God bless you
Posted on Oct 15, 2012
My sole F63 treadmill squeaks when inclining from 0to5. It makes no noise after that, or coming back down.
Please LUBE very the shaft motor, with Grease.
and RUN again.
Otherwise the ball bearing inside is Defective and repair.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Treadmill Repair Incline Motor Lubrication
Nov 25, 2017 | Exercise & Fitness
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
My sole F63 treadmill is stuck up in the storage state. I tried to use the yellow lever and it isn't lowering and I can not use it!
Lift the treadmill slightly to take pressure off of the locking pin as you work the release lever.
Oct 08, 2014 | Sole Fitness F63 Treadmill
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
My sole treadmil makes noise when changing levels
God bless you
Oct 14, 2012 | RTO Sole F80 Treadmill
Purchased 26" tv december 2010
Hi The first thing I would do is check to see if all the connections are in properly and make sure none of the leads are loose on the back of the tv. Then if problem continues phone Argos and see if they can help.
Matthew
May 31, 2011 | Televison & Video
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
Can i use your lubricant on my solo s77
The lubricant is suitable for all tradmills, so yes you can use it. If you need help with the applicatin, let me know. The directions are easy to follow.
Hope this helps
Nov 18, 2010 | Icon Treadmill Accessory Kit Surge...
Exercise & Fitness Logo
47 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
