Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine wont spin
Every thing on my washer works great, except it won't spin.. it goes through all of the cycles, it agitates fine, everything is good until it is supposed to spin, then you here the motor acting like it is spinning, but the drum is standing still. Any suggestions?
  • 3 more comments
  • zapco658 Jul 15, 2008
    I hvae a kenmore washing machine. Goes through all cycles with no problems, but when it comes to the spin cyle, it will not do anything!Nothing at all.
  • Anonymous Jul 19, 2008
    the spin cycle just will not spin. everything else works but the spin.
  • Anonymous Mar 12, 2014
    starts and runs thru agitate, but loading humming when time to spin. I wait 30 minutes, and all is fine, until next spin cycle.
  • Anonymous Mar 21, 2014
    all cycles work except spin clutch spins but agitator dont
  • Anonymous Mar 27, 2014
    work good except for the spin cycle
  • 291 Answers
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Posted on Aug 29, 2007
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Washing Machine, Apliance help.
Washer works great during the wash and rinse cycle,the agitator works fine for those but the drum will not spin on the spin cycle. A couple of things go on when the washer goes from wash to spin, the motor pivots, tightens the belt and the drum spins up to speed. I had the same problem on my Maytag, I replaced the belt and the pullys and it has been washing and spinning great ever since, The belts can be accessed by removing the front panel, or disconnecting the machine and laying it down, if you see a lot of fine black dust,(rubber), the belt is probably worn out, change the pullys also at this time, it is cheap insurance that everything will go well. make sure that the motor pivots smoothly, if it does not, correct this issue first and run it. That may solve your problem, A great website that i use for parts and info is They have parts diagrams for tons of appliances, and stock parts, I have used them many times in the past.
on Jan 04, 2010 | Washing Machines
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
1 year old kenmore washing machine won't spin, agitator works OK and the water drains, just won't spin.
you have a bad door switch everything on a washer works fine with a bad door switch except the spin cycle
Jun 07, 2009 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
372 people viewed this question
Dan Webster
Dan Webster
Sal De
