Hampton bay air conditioner Model hbd160: how many btu is this model
How many btu is this model
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
SOURCE: master control knob
I got a replacement master control knob from http://www.repairclinic.com, item number 868845.
Posted on Aug 06, 2008
SOURCE: Owner's manual for a Hampton Bay HBTE120 Air Conditioner?
http://www.appliancefactoryparts.com/content/pdfs/118255.pdf
this is the pdf of the manual for that particular model of a/c.
hope that helps.
Posted on Aug 29, 2008
  • 334 Answers
SOURCE: need part
Hey there, try checking out the following site to see if you can find what you need.
http://www.repairclinic.com/Appliance-Parts?s=t-HBQ100-%3d%3d
Posted on Jun 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: Hampton Bay air conditioner wall unit doesn't cool
Might be the CAPACITOR
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Model 25373156301 air conditioner: What are the dimensions? How many BTU? Last year they were manufactured?
Found very little on that model: Kenmore 25373156301
24 in. Wide, 18 in. Height, 24 in. Depth and approx. 112 lbs.
15,000 BTU, Parts are still available.
Unknown date(s) of manufacture but Sears (Kenmore) does have similar (exact matches) models still in production.
Sep 13, 2014 | Heating & Cooling
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
Do you know the btu rating for Teledyne Laars Mark V
All heaters have a data plate. Often the model # is the BTU's. For example, H400 is a 400,000 BTU output. The plate is on the inner firewall. All heater have different BTU's.
Aug 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Need information on the btu
Hey, Back -on line , & the answer to your question is ...go to webpage or type in whirlpool model window unit mod acq189! This equals to 17,800 btu 15 amps 220 volts 3 speed.
Jan 08, 2009 | Whirlpool Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
