Ht tx500 red light on but dvd not working and i tried to turn off and on and press the power for 10 second but nothing happen. any body tell what me do pls.......
  • 128 Answers
SOURCE: Unit won't allow me to change modes
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Posted on Jan 19, 2006
SOURCE: Emerson AV101 System
there is a reset button on the back u will need a ball point pen to push it in and it is very small.
Posted on Nov 19, 2007
SOURCE: Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Posted on Jan 11, 2009
djicenova
  • 319 Answers
SOURCE: Region Free CODE available HERE
awesome!
Posted on Apr 01, 2009
srinivasb81
  • 51 Answers
SOURCE: dvd
This is problem is due to the power card problem so you please replace the power card and try with this surely you can resolve your issue.
Posted on Apr 12, 2009
Sylvania DV220SL8 won't play DVDs, DVD tray won't open
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Jan 09, 2010 | Sylvania DV220SL8 DVD Player/VCR
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
hi there
this is what i did
Dec 13, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
15 people viewed this question
 Grubhead
Grubhead
