Question about Canon FAXPHONE L80 Laser
Progamming a number
Would you be able to help me program a number into our business fax machine? The previous managers did not leave the instructions booklet.
    President:
  • 1,114 Answers
You can download the manual from the link below: http://files-upload.com/files/465984/FAXPHONE_L80_Users_Guide_EN.pdf See page 6_3 Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
  • 32 Answers
I have a book, email me your fax number and I will fax you the page of instructions.
SOURCE:
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
How do i change programed number
Hello Ms Nelling,
You can change the programmed numbers by simply programming new numbers on the saved position.
Press the MENU/SET button and select FAX \ Setup Quick Dial and then choose whether you want to program a speed dial or a one touch button.
If you had previously programmed a 1 touch on button 3, just select that 1-touch and it will ask you if you wish to change the current settings.
Thanks,
Pat
Apr 14, 2011 | Brother IntelliFax-2820 Laser Fax
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Resetting fax name and number
GO MENU, INITIAL SETUP ,THERE U CAN FIND
May 26, 2010 | Brother 2440C Colour Plain Paper Inkjet...
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
ONLINE INSTRUCTIONS TO PROGRAM SPEED DIAL NUMBERS
please sent me yours e-mail address and i will sent you the user manual as attachment my e-mail is as follow: [email protected]
Jun 24, 2009 | Ricoh FAX2050L Plain Paper Laser
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
System Programming, Busy No Answer on an analog fax extension
Programm those 2 extension in memoru 4-14 and 4-15. So when
one is busy rolls over to the second one.
Oct 12, 2007 | NEC Electra Elite 32D-1 Corded Phone
Canon FAXPHONE L80 Laser Logo
Clive
Clive
old marine
old marine
Ekse
