Question about Exercise & Fitness
Powertrek treadmill, where would I get a replacement motor
3 Suggested Answers
georgiejm201
  • 54 Answers
SOURCE: my powertrek treadmill when switched
Typically when this occurs, it is an indication of a short circuit in the motor controller. Please follow the following steps to solve the problem:
First Test
1)Unplug the treadmill from the wall.
2)Remove the motor hood.
3)Unplug the speed wires from the controller. On many controllers, you will have 2 to 3 wires that control speed and many are labeled H, W, and L. If you cannot find the speed wires, do not guess, contact us with your make and model number and we will try to help you with the wiring.
4)Return the treadmill to a usable position once the speed wires are disconnected and plug the treadmill back in.
5)If the treadmill begins to run at full speed, the motor control has failed and requires replacement.
6)If the treadmill does not run at full speed you could have a speed input problem, wiring problem, or another short circuit.
Second Test
1)Unplug your treadmill from the wall.
3)Check and see if your controller has three speed wires labeled H, W, and L or a unified wiring harness labeled H, W, and L from the console. If not, you have a digital controller and full speed upon power up is always a failed controller. No need for further testing...you need to replace the controller.
Posted on Jan 11, 2011
ercupa190
  • 12223 Answers
SOURCE: powertrek treadmill jerks to start and straight away to stop repeatedly. what can be a problem?
1) ;LUBE THE DECK BELT very well, this a sign for a deck worn.
2) lube the rollers bearings too.
3) Measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram
Good Bless you
Posted on Jul 04, 2012
I purchased a Manual Powertrek treadmill possibly approx 5yrs ago,lost the manual and there is no part number on the treadmill,how do i contact Powertrek direct,thankyou
go google and type in ---powertrek-- find their page that has a "contact us" section click on that and there should be an address, phone number, fax number and e-mail address.
Nov 07, 2016 | Health & Beauty
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
Powertrek treadmill jerks to start and straight away to stop repeatedly. what can be a problem?
see the diagram
Good Bless you
Jul 03, 2012 | Exercise & Fitness
Powertrek slimline treadmill user manual
my treadmills makes a strage noise when i use it.
May 01, 2011 | Sport & Outdoor - Others
My powertrek treadmill when switched on goes straight to full speed & will go at this speed only
First Test
Second Test
Jan 11, 2011 | Exercise & Fitness
How do i tighten and centre the belt on POWERTREK
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 13, 2010 | Exercise & Fitness
Exercise & Fitness Logo
15 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
