Question about Whirlpool Ovens
Oven not heating properly
My whirlpool oven model WOS51E wont turn on. When I hit the bake feature it indicates feature not available
  • Michael Brown
    Michael Brown Dec 24, 2015
    We had a power outage and when the power came back on we attempted to use the oven. The display said; "Feature Not Available", I reset the oven at the power panel, then reset the oven at the display and it has continued to work properly.
  • Whirlpool Master
  • 2,342 Answers
Most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Posted on Dec 24, 2015
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
dmftrucker
  • 1922 Answers
SOURCE: Oven not heating properly
you sure you have 240volts at the unit??? chk for 120+120 volts to get 240volts,one leg out and you'll have little to no heat condition
Posted on Jul 29, 2009
  • 41 Answers
SOURCE: We have a whirlpool oven model #RBS305PDB8 last
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
  • 75 Answers
SOURCE: Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Posted on Nov 20, 2009
  • 3741 Answers
SOURCE: Whirlpool Oven Model GS440LEMQ bake eventually turns off
As per the problem you submitted ,According to the manufacturer service pointer cause of the intermittent bake burner operation is improper air flow to the burner.
The correction is to replace the bake burner with the new modified burner and igniter assembly.
- The part number for the burner & igniter assembly is AP3598752
http://www.appliancepartspros.com/part_details.aspx?part_id=3598752 --------- to get more help please click on this link directly http://www.applianceaid.com/gas.html
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 03, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
When I select bake, broil, etc, I get the message-feature not available
If is 6 months old call for warranty repair, turn off circuit breaker for a minute then repower this may clear it if not again call for warranty service
Jan 30, 2014 | Whirlpool RBD305PD Electric Double Oven
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
138 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
