Question about Frigidaire ATF6000ES Front Load Washer
Front load washer wont spin
Every thing work but no spin was told to change control board and did but same thing happens (fills agitates drains but no spin) need help thanks
  • 2 more comments
  • broken06 Aug 29, 2007
    yes the motor works everything works but when its time to spin it wont spin it fills agitates drains but no spin
    motor is a 3 phase 195V 17,500 RPM
    MODLE #J52AAC-0102
    PIN#134362500
    THANKS
    IT WAS THE MOTOR CONTROL BOARD
  • broken06 Aug 30, 2007
    sorry about the capital letters .i was in a hurry and didnt realise until it was to late. that was my answer to Did you change the main control of the motor control.so when i changed the motor control like you suggested it did not help the problem so i would say that your answer did not help
  • dougmille986 Oct 11, 2008
    I have a Frigidaire LTF214OES1 washer that will not spin. I can make the unit spin by going into the diagnostic funtion. There is an error code E42 (replace control module) I have replaced the Control Boad and the Control Board Motor. Still the same problem it will not spin. Had someone suggested replacing the Motor.
    New Friend:
Hi, Problems with my washer machine. It starts washing but when start the rinse cycle it wont spin no more and it wond drain either.
Posted on Jun 14, 2011
    Problem Solver:
  • 10 Answers
I have a Frigidaire Affinity and the same thing happened to me. After looking on this website I found someone who told me to change the door latch assembly. I went to my local parts supplier and bought a new door latch assembly for $53. My husband replaced the door latch, and it works like new! The good news is the replacement part is better made than the original. The parts guy said he's never seen one fail a 2nd time. This is a cheap fix to a serious problem.
Posted on Jan 02, 2009
My Fridgidare did the same thing. There is a bolt on the back that kept coming off. My last repair person lock-tighted the bolt on and it hasn't come undone since. Unfortunately, I will never get the bolt off. I think the quality of this specific machine is horrible. I am having my 4th service call in less than 12 months. I'm glad I purchased the extended warranty.
Posted on Oct 01, 2007
  • 725 Answers
Hi, Did you change the main control of the motor control. the motor control is controls the speed and the spin cycle...I also have had bad door locks keeping th washer from going into a spin cycle.. let me know if you change them and what happens..
Posted on Aug 29, 2007
  • 2 more comments
  • Franklin Ouchida
    Franklin Ouchida Aug 30, 2007
    "IT WAS THE MOTOR CONTROL BOARD" then why would you rate me NOT helpful.. if it was the motor control. if that was the solution?? three things can stop it from spinning main control-motor control or door lock..sorry I was not helpful to you!
  • Franklin Ouchida
    So it was NOT the Motor control. the one next to the motor? have you found out what the problem is? let me know when you do? Krazytech
  • Franklin Ouchida
    if it agitates then it couldn't be the belt
  • Franklin Ouchida
    Franklin Ouchida Aug 31, 2007
    dovi had the best solution? a broken belt ? then how did it agitate?
  • 641 Answers
Open the rear panel and look for a broken belt and does the motor spins. In case motor doesn't spin, check on its tags for 115/220V. Let me know with your results,for further assistance if will be needed. Good luck!
Posted on Aug 28, 2007
2 Suggested Answers
SOURCE:
mrfixit3667
  • 262 Answers
SOURCE: Kenmor top load Washer, Wshr fills, agitates, wont spin or drain
The Lid switch is the most common problem with what you have descibed.
some of the lid switches are located in the control area and some are on the right side center lid area and their is a hole where the lid has a plastic pin that presses it.
Posted on Jan 12, 2010
My ATF6000ES Front Loading washer runs on any cycle for about 5 minutes then stops, and the display resets to the start and nothing more happens. Got an E48 code and ran "test 7" and the tub did not
Hello Nick Jensen, thanks for your post!
From what you have described your Frigidaire washer is displaying an error code of "E48" and you have changed the control board with the problem continuing to be present. An "E48" error code could be a possible problem with your door lock assembly, motor control board, or control panel. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. I hope this is helpful. -Matt
Jan 30, 2015 | Frigidaire Affinity ATF6000F Front Load...
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
likely the lid switch is bad - if not the ECU/timer is.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 43042 Front Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,319 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
