Question about Husky HUS-CN15 Wine Chiller
HUS-CN15 not cooling
Not cooling tempreture not going down
Fridge is not getting cold, fans are running and outside casing feels cold to touch but internal warm think faulty compressor how can check and how easy to chnge
If fans are running and compressor is not check to see if the unit has a starting capacitor for the compressor - check it for capacitance value and change if necessary. If still nothing, using a voltmeter check to see if current is reaching the starting windings of compressor. If nothing, then maybe the thermostat is defective. But if current appears at terminal and the start capacitor is good, then the motor has definitely gone to heaven.
if compressor is running and refrigerator is warm, either the self defrost mechanism is not working or perhaps you may be in need of refrigerant.
To change unit you need vacuum pump, solder and soldering equipment, schrader valve, refrigerant scale and refrigerant, gauges, rags, emery paper, etc.
Aug 28, 2015 | Husky HUS-CN15 Wine Chiller
Why are Both lights flashing on my huscn15?fan doesn't start either
The lights flashing made be signaling a trouble code. If you have the owners manual or can go to the mfg website and download the manual, you may be able to find the troubleshooting section for the correct solution.
Jul 07, 2014 | Husky HUS-CN15 Wine Chiller
Set the temperature
I can't get my temps to adjust
1 stay warm
1 stays cold
Jun 11, 2014 | Husky HUS-CN15 Wine Chiller
The temperature will not adjust. none of the refrigerators are getting cold but fans are running
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
Aug 14, 2013 | Husky HUS-CN15 Wine Chiller
Husky cn15 88 problem
First things first, check the power supply. If there is power at the pluf then I would look at the temperature control. Check to make sure it is closing and calling for the compressor to be coming on, that will also control the condenser fan motor. Good luck
Sep 08, 2012 | Husky HUS-CN15 Wine Chiller
Whirpool cook top surface light countiune on even surface are cold
How long does it take for the light to finally go off?or does the light ever go off when a cooktop decrease in tempreture has to reach the tempreture set by the factory for that light to go off. Sounds like a thermal switch which controls the hot surface light is stuck closed If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.If you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Whirlpool RCC3024 Electric Cooktop
Heater fan blows out cool air then car over heats then blows hot and cools the car back off. It does this over and over. Changed thermastat and waterpump already.
is your vehicle automat climate control ?
suspect the tempreture sensor in the vehicle is defective and is not giving a true reading of the relationship between the set tempreture and the true air tempreture.
Nov 13, 2009 | 2002 Pontiac Grand Am
Husky HUS-CN15 Wine Chiller Logo
37 people viewed this question
Top Husky Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Husky Refrigerator Expert? Answer questions, earn points and help others
