Question about Refrigerators
Gsh22jfte why is freezer constantly freezing
Why does my freezer not freeze?
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
Jun 29, 2015 | Freezers
Why does my upright freezer run constantly but it's not freezing anymore
what you need is a new Compressor,w/o Electricals part number 5304475092
Jan 14, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer runs constantly and ices up
It sounds like the thermostat has failed. Have it replaced and it should take care of your problem. Hope this helps, good luck!
Sep 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My roper refrigerator(2door)constatly freezes up--WHIRLPOOL PROD.
Check the defrost timer, mark it and see if the dial rotates. It takes a while to see if it moves. Make sure food in the freezer is not blocking the openings for air to move around.
May 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Kenmore Elite Trio = clicking and fan running constantly
Sounds like a problem with the compressor.  Get a service tech in.
Nov 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cold
I had the same problem with fridge/freezer and repair man told me NOT to use anything that has been in freezer as what is happening is that it is constantly freezing and defrosting because there is not enough gas in the system to cool the appliance. It is possible to re-gas the appliance but service engineer advised me to claim a new fridge/freezer from company which I did. Please do NOT eat anything from freezer as could make you ill.
May 01, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
