Question about Refrigerators
Top mount kenmore refridgerator model 106.76932400
Refrigerator not cooling properly
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Posted on Aug 13, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
aasc
  • 1606 Answers
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Refrigerator Cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
heatman101
  • 43501 Answers
SOURCE: kenmore model 50503990 not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsfj
Posted on Sep 29, 2010
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
Looking for a manual for Kenmore Elite Refridgerator MFG 2005 Model #106.74219400
http://www.managemylife.com/mmh/owner_manuals/5877
/KENMORE-ELITE-Top-Mount-Refrigerator-L0408620
Apr 20, 2011 | Kenmore Top Freezer Refrigerator
Have Kenmore model 69882990. Top mount freezer. Water drips from top of refridgerator compt amd gets in drawers. Any thoughts. Thanks for the help.
Check the drain tube for blockage.
http://www.acmehowto.com/howto/appliance/refrigerator/check/draintube.php
Nov 27, 2010 | Refrigerators
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
Top freezer refridgerator freezer works refridgerator not cold. back coils are warm.
heatman101
Mar 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore model 50503990 not cooling
heatman101
fsfj
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
How do i defrost without unplugging the entire refrigerator?
The freezer actualy cools the refrigerator as well and regardless the refrigerator will not cool as you unthaw freezer. unless this is a very old model that doesn't defrost then there is something causing this situation to happen. If you are wanting to repair let me know more about unit and see if I can help.
Apr 25, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
