WE HAVE MG GALAXY 3000 UPS SINGLE UNIT / CF HAVING COOLING FAULT
SOURCE: I have an MGE Galaxy 3000 15KVA which i replaced the batteries.
This is Easy,
MGE software is exclusive to them, they do this so that in the event the UPS needs any work you have to use them for remedial work, the problem is because they hold the monopoly they charge through the roof for parts and labour. you will need a factory trained engineer to turn up with a laptop to switch off the "Maintenance Alarms" I have an engineer that has the Software and availabilty to parts and we are much cheaper than MGE direct.
if you need any UPS help contact Glenn Prince @ Adept Power Solutions Ltd 01264 326726 or go to website www.adeptpower.co.uk
Posted on May 13, 2010
SOURCE: hello Ive got cooling fault on my galaxy 3000 can
try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Posted on Dec 03, 2010
  • 14 Answers
SOURCE: Hi! Ive got "cooling fault" on my galaxy 3000. Can
hello
If this galaxy 3000 is of European Type ( that is having a radiator with coolant) , then after following proper BYPASS/Shutdown procedures, you could level the coolant in the radiator. You may require the tool kit that the supplier normally supply for this type of job.Generally the design was such that no evaporation could occur, however at times the top up is required. It may be as little as 20 (millilitre) Please check also the cooling fan just below the capacitor assembly. I hope this will help
Posted on Jun 11, 2011
epettingill
  • 175 Answers
SOURCE: MGE Galaxy 3000 UPS, do i require to reconfigure
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Posted on Oct 21, 2011
epettingill
  • 175 Answers
SOURCE: I have mge galaxy 3000
sounds like you have a battery in thermal runaway. That means your battery could catch fire. I don't know what refroidissemt is. Your spelling is wrong. Go back to the UPS and write down the right alarms. Then I can help you.
Posted on Oct 27, 2011
Temperature fault. Q5N open
pls cheak by pas slecter not normal position load on by pas temperature fault 1st cheak coling water 2nd room temp 3rd cheak temperature sencer battary breakr to batt bank side 2 wair
Jul 25, 2013 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
Oct 19, 2011 | MGE Galaxy 3000 UPS System
I have mge galaxy 3000 single unit 30 kv who shown those messages: defaut refroidissemt defaut temp batterie thank you for you help
Sep 24, 2011 | MGE Galaxy 3000 UPS System
Galaxy 3000 30kVA showns battery charge fault.beacause battery?
UPS battery must be tested individually before you can decide it is a battery problem or if charging fault can cause by defective rectifier/charger board.
Sep 09, 2011 | MGE Galaxy 3000 UPS System
hello
Jun 08, 2011 | MGE UPS Galaxy 3000 UPS System
I have a cooling fault error displayed on my galaxy 3000 mge ups please help on how to solve it
u must be open the tope of cape and u will see top of the back site in ups condenser I mean cooling system like AC condenser u will have to pull it off the sensor switch it sure u problem will be resolve
Sep 15, 2010 | Refrigerators
Hello Ive got cooling fault on my galaxy 3000 can u help
Sep 04, 2010 | MGE UPS Galaxy 3000 UPS System
Rectifire internal fault
the mge galaxy 3000 ups dont start atall when switch to normal position
Apr 06, 2009 | MGE Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Jul 02, 2008 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
