Question about Home
Aqualisa quartz digital shower won't turn off
Three times now my shower has continued to run after turning it off. The light on the pushbutton goes out and the pump stops working but both hat and cold run at gravity pressure. Swiching main electrical power on and off has no effect. Neither does pressing the normal or boost button (no lights come on. What seems to work is to turn of the hot and cold water feed and them press the button. Pushbutton light comes on and pump starts - switching off the pushbutton makes the usual shut off sounds. Then opening the water feeds puts things back to normal. What is the permanent cure?
2 Suggested Answers
  • 3 Answers
SOURCE: The 'boost' button on my
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Posted on Aug 02, 2011
Testimonial: "Very helpful reply thankyou"
Where is thermostatic cartridge located in aqualisa quartz shower
watch this video as this should be of some help
https://www.youtube.com/watch?v=djUi3SB5-y8
Aug 28, 2017 | Home
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
Aqualisa quartz electric 8.5
This just happened to me this morning, you found a fix for it?
Sep 06, 2012 | Watches
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
Dec 28, 2009 | Home
Aqualisa quartz shower. Knocking / dripping type noise coming from pump when powered but not turned on. Any ideas???
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
Nov 15, 2009 | Home
On and Off control not fully working
I've never worked with an Aqualisa, but often times a problem like that is simply mineral build-up within the valve components. I would recommend turning the water off at the main and carefully disassembling the valve. Give it a good clean with some CLR and a toothpick. If the valve has any springs you may look into replacing them, as that is a common problem as well.
DO NOT forget to turn the water off at the main shutoff point, or you're gonna be in for the shower of your life once you take that valve out. You shouldn't need much besides a phillips screwdriver, and possibly an allen wrench and some pliers.
Mar 27, 2009 | Home
Home Logo
721 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
