Back to:
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Panasonic Micro-combi
posted by LosLins on Aug 28, 2007
Oven fine but microwave not working?
Comment by LosLins, posted on Oct 24, 2007
Thanks,but it has been so long I have had to buy a new one.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 22, 2007
Thanks for Trying (70)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2984 votes
You mean it doesn't heat?
Any other symptoms or problems?
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
Rating Locked! (?) LosLins has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Panasonic Micro-combi:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
we have an intergrated Bosch microwave oven (approx 26...
GE Spacemaker (JVM1640SJ) Microwave Oven
We just purchased a manufactured home that has the GE...
Sharp R-1610 / R-1611 / R-1612 1000 Watts...
I was cleaning the microwave and removed the plastic vent...
Microwave was not heating the food and we tried several...
Microwave Ovens
Have a kitchenaid superba part no. 4450786A with the probe...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
