Was mowing, cut it off for a minute, went to restart and will not do anything, has volts but will not turn or crank
SOURCE: We have a 2166 Cub Cadet. After mowing the lawn
Could be couple of things...blockage in fuel filter....tank cap has blocked bleed hole pressurising fuel tank....magneto either coil or condensor on way out
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
SOURCE: engine shuts off
The tank breather is in the filler cap, just try slackening the cap when it starts to die, if it picks up again replace the cap.
