Question about Garden
What is causing the PTO cable on my John Deere LA115 to get hot and burn into?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Have a 2009 John Deere LA115 and need a belt diagram.
For a belt (replacement) diagram, contact John Deere directly.
Apr 18, 2017 | John Deere Garden
John Deere 285 lawn tractor pto works but the wire keeps melting?
U need to inspect wiring for wear thuroly. Some is internal from age causing resistenc. Obtain a shopbook or somethin similar in library or online
Oct 08, 2015 | John Deere Tractor Starter 285 345 2243...
What causes gas to mix in your oil on a john deere LA115 riding mower
carb float sticking and flooding the carb which runs directly into the block .
Aug 21, 2015 | John Deere Garden
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
How come I can't start my John Deere LA115 after
The Reverse Interrupt Override switch is supposed to let you keep the blades engaged while using reverse. Be sure PTO is off and brake pedal is depressed and try to start engine. If it wont start/ wont crank then a switch is stuck or failed or there is a broken wire. Switches that are involved with PTO operation are the seat switch, reverse switch, PTO switch, and RIO switch. The starting system requires neutral ( no reverse activated), brake switch and PTO switch off.
Sep 02, 2014 | Garden
Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
Jul 16, 2014 | John Deere Garden
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
