Question about Go Ped ESR750Ex Electric Scooter
Goped flashing red light - Go Ped ESR750Ex Electric Scooter
My goped sport engine shut off and wont start again, what I can do?
Try the steps on this website. http://goped.8m.com/racingpages/troubleshooting.html
May 30, 2014 | Go Ped GSR Sport Gas Powered City Scooter
I'm looking for an exploded view diagram for my Goped CY46 engine. Do you know where I can obtain one?
You should contact GoPed at www.goped.com. They don't show that engine number or photo on the website so you may want to call 1-755-782-3202 or email walshj@goped.com.. They are located in Minden Nevada, mountain time zone. Below is a diagram of a G23LH engine. Yours will be very similar. Please rate my answer. Thanks. tombones49_220.gif
Aug 05, 2011 | California X280R Motorcycles
How to put a tire back on the axle of a goped grt46 and with spacers and washers
Simple, go to goped.com and find the Video section of the website there you will find a link to videos that will help.
1 put axle through frame
2 spacer and possibly a washer or two on the axle. Then wheel but make sure the sprocket on the wheel is lined up with the sprocket on the motor as you may need to add or take away a washer to get the alignment just right.
3 install wheel and put chain on the sprocket. Note, you may need to move the axle out of the way to get the chain on the sprocket and then wheel on the axle.
4 install spacer for the fender.
5 install fender
6 install and tighten axle.
Done
Mar 12, 2011 | Go Ped Toys
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Goped wont stay running
try cleaning you carb and spark plug
also check your fuel mixture
Jul 07, 2009 | Go Ped Know Ped Goped Push Scooter
Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
Jan 25, 2009 | Go Ped Know Ped Goped Push Scooter
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Go Ped ESR750Ex  Electric Scooter Logo
43 people viewed this question
Top Go Ped Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
