Question about Watches
Citizen wingman vintage c080, changed the battery and all the digital displays work fine, the analog 9second hand) will not run. the manual says the crown has two positions to set the analog, first position out will move second hand etc. The crown comes out to one position and it then moves the minute and hour hands? I've tried move force than it should take to get the crown out to a second position! Thanks for any help and or idea's!
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Posted on Feb 22, 2008
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
disap1
  • 98 Answers
SOURCE: The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Posted on Jan 09, 2010
  • 2501 Answers
SOURCE: Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Posted on Jan 26, 2010
Citizen Eco-Drive Blue Angel Watch C650. I can't get the analog to match the digital. i have reset everything to the O positon. Reset time, calendar.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all citizen watch manuals. Rate me, please.
Mar 02, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My Citizen Navihawk analog hands work, LCD Blank??
Being able to tap it and bring it back is a sure sign that there is a contact problem most likely in the circuit board. This is the worst case scenario. I would try going to a watch maker/technician to see of having the watch AC'd or reset fixes the problem. If not then I would have them look at the circuit board/movement. This may have been damaged during battery placement from too much pressure.
If you have trouble finding a qualified watch maker/technician you can go to Citizen.com to look up their service center or an authorized service center near you.
Sep 21, 2009 | Citizen Navitach JQ8020-52Y wristwatch
Hands don't move - digital stuff works
the hands could be silghtly bent or to tight for them to move if not change the battery
Jun 02, 2009 | Citizen Watches
Citizen C080 Setting year
Find equivalent calendar years to substitute for the current one!
For example, 2010 = 1993 = 1999
2012 will be a problem, but for the most part, correlations exist within the programmable range.
How to find them? PERPETUAL CALENDARS:
http://www.vpcalendar.net/Year_Correlations.html
There, now get back to practicing your slide rule skills!
Mar 13, 2009 | Citizen Watches
How to set the digital and analog as the same time
They are supposed to move in unison, if you are setting the digital time and the analog is not moving, there is a problem with the watch and it could need service. Here is a link to the manual for the watch, the movement for the Blue Angels is a C300 and you will see the manual also states the time mechanisms move in tandem.
http://www.citizenwatch.jp/support/pdf/coa/c300.pdf
Citizen does have service centers all over the globe, I am sure you can get the watch fixed if it does need service, You can find the local service center at the Citizen web site. Hope that helps.
Jan 30, 2009 | Citizen Blue Angels Skyhawk Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
203 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
