Question about Garden
Stihl fs90r won't rev up/ like screen plugged
2 Suggested Answers
gobarnto
  • 3 Answers
SOURCE: I have a new Stihl FS90R Trimmer...Idles fine but
My nephew had a problem with his Stihl FS55R trimmer, sez it would run on high for a few then quit. Sez it restarts easy and runs on idle with no problem. I pulled carb & found fuel screen full of fine contaminant. This is the screen you see when you drop the bottom pan of the carb. (single screw does it). Reassembled and the trimmer runs on high speed w/o problems. If your primer bulb doesn't pop right back up when you punch it down, it means that the fuel can't get past that screen....
Posted on Apr 04, 2012
My stihl fs90r motor run faster than the part with the weef eater line
sounds like the shaft isn't engaged properly at the engine end or the cutter head. or the inner shaft could be damaged, but most likely it will be that the head isn't on properly
Aug 24, 2015 | Stihl Garden
How do i replace tank fuel filter on a stihl model fs90r
The filter is hanging on a flexible fuel line in the tank. make a hook on the end of a piece of wire and go fishing.
Jun 01, 2015 | Stihl Garden
Stihl FS90R weedeater trigger sticks
Replace the throttle cable they bad to fray at carburetor end.
Apr 05, 2015 | Stihl Garden
How do I repair a Stihl FS90R weedeater handle that sticks?
if lubing the hole handle an cord with wd40 it could be a jam somewhere in the handle. good luck my friend
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
Jul 03, 2012 | Stihl Garden
Will Stihl FS90R trimmer run with cracked primer bubble.
Hi, it will run because the fuel tank is on top of the engine, but not very well and should be replaced. Regards Phil
Jul 21, 2011 | Garden
I have a new Stihl FS90R Trimmer...Idles fine but dies when given gas to rev up. Tried to adjust the carb out. Did not help. I have two of these.Changed the carbs and the same thing happened. The same carb...
Nov 07, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
